Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
LCA relocation bracket install
Old Sep 18, 2011 | 10:55 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Finally welded my LCA relocation brackets to my Currie 9" housing. I was a little nervous about welding on such a great piece of fabrication, but I'm happy with how it came out.
Check out my 9" build in the Drivetrain section.
Old Sep 23, 2011 | 04:49 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: LCA relocation bracket install
Is the weld a little undercut in spots, or is it just the lighting in the photo?
Referring mainly to the bottom right in the first picture, and on both of the vertically oriented welds
Old Sep 23, 2011 | 06:49 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Looks good to me. You could get sleeves and weld one in the center of the upper bolt like the 10 and 9 bolt kits do. I do find it ironic how many aftermarket carriers don't have them by default for these applications. If someone spends 900-1000 on carrier/axle kit with basic lca hookup the company should at least offer lca brackets.
Old Sep 23, 2011 | 08:02 AM
BPWilliams's Avatar
From the looks of the pictures it looks like the brackets are welded on backwards? The spring perches should be on the cover side? the shock mounts are on the carrier side?
Old Sep 23, 2011 | 08:54 AM
Engine: 383 SBC
Looks okay to me. 9" are front loading so center opening should also be open facing with brackets and shock mounts should be flat. The picture is a little misleading it almost looks like the cover bside not the carrier side.
Old Sep 23, 2011 | 09:34 AM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
that the angle the picture was taking it looks like an optical illusion, they are welding on correctly, you actually are looking into the housing and seeing the back side of the cover. Its hard to explain lol
Old Sep 23, 2011 | 07:33 PM
BPWilliams's Avatar
LOL yes it is an optical illusion...
Old Sep 23, 2011 | 08:15 PM
Car: '91 LS6/T56/9"
Engine: LS6
Here's an issue I'm having with this rear:
https://www.thirdgen.org/forums/tran...g-strange.html
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
toronto formula
Nov 10, 2015 06:17 AM
TheExaminer
Aug 25, 2015 07:34 PM
