Number of keys
Car: Firebird
Engine: 5737cc
Number of keys
How many keys these cars got from the dealer/factory
I mean i have 4 keys with the black plastic cover on them (ignition keys i guess) and another 4 normal ones for doors and trunk (dunno if they should be universal or not since the door lock needs to be replaced) .Was there a standard for the number of keys?
Also since I have that door lock problem ,were the keys from ignition also good on the doors (like modern cars these days)?VATS seems to only care about the chip on the key not how the key looks.
cheers and thanks in advance.
Re: Number of keys
I got 2 ea.
Ignition ones were square w black plastic covers; door ones were oval w no plastic covers. Ign key fit ign only. Door one fit everything else (hatch, doors, box in rear, etc.)
Back in those days, keys had letters, that corresponded to the grooves along their length. Most letters would only go into a lock for the same letter. All cars in a given year got the same letters. They ran from A/B (ign/door) to J/K and then re-started. If memory serves, there was one combo that weren't adjacent letters; E/H maybe.
You are correct: VATS only cares about the resistance of the resistor in the key, not its shape. As long as it goes into the lock and has the right resistor it will work.
Replacing just one door lock would create a real PITA. I'd avoid that if possible.
Car: Firebird
Engine: 5737cc
Re: Number of keys
Ok so why I have 4 ignition keys is a mystery ,thou since they all work ,have the same shape,and same resistence chip , they must be somehow "original".2 have round shaped heads wrapped in the black plastic and 2 are square in the same plastic.
Why give them a lock if all cars got the same key ...boggles the mind if you think about it.Guess they had locks to prevent animals sleeping in over night
I know I have to change all locks .The driver side lock opens with a screwdriver...dunno if thats normal but usually cars that were broken into the past open that way.The right door seems to have the lock disconected .The car has central locking with remote control from the alarm system so probably kept one door in case the car runs out of battery.The trunk only opens with a key.
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
Re: Number of keys
The 87 came with 3 sets, 2 metal set of keys with the black plastic covers, and one plastic set that are in a business card looking thing for your wallet.
Car: Firebird
Engine: 5737cc
Re: Number of keys
so we got 4 ,3 and 2 sets till now...anyone with 5
guess each car had more than 4,3 or 2 and maybe dealers gave away keys at random but why would they keep a spare?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Number of keys
Mine also came with 2 sets,could be someone made some extra spares.
Car: 1983 Z28
Engine: 385 Fastburn
Re: Number of keys
I'm guessing someone made extras.
Also, I'm not positive about all of them having black covers, my keys are cut from NOS blanks and don't have the black covers.
Are you sure about any vats key working regardless of how it's cut? that doesn't make any sense, my understanding is that they worked together. i.e. the vats chip had to be present AND the key had to be cut right in order to turn.
Either way, glad I have a pre-vats car.
Engine: 4++,350 & 305 CIs
Re: Number of keys
NOS blank stock keys don't have the plastic covers but you can add them by just sliding them on. Original keys had the plastic molded on and unless you cut or melt it off, its staying.
If you buy a ign lock from GM it comes with the plastic keys. I just got one for one of my VATS cars and they had the molded on plastic key covers.
Re: Number of keys
And of course, VATS doesn't somehow invalidate the tumbler mechanism of the lock; so yeah, not only does the key have to be cut from the right blank so it will GO INTO the lock in the first place, but it ALSO has to have the right teeth cut in it so that it will turn, AND it has to have the right resistor. 3 features in that system, that the key must match the lock and other security devices.
You're right, I forgot about the credit-card spare that they started supplying in the late 80s. So I guess you could say, 2½ sets.
Car: Firebird
Engine: 5737cc
Re: Number of keys
If the car would not have vats and the ignition/steering wheel would not be locked the car could be started without key I guess.
Engine: 5.0 EFI
Re: Number of keys
the driver side door unlocks with a screwdriver (thats not normal ,no matter how bad people think the locks are i refuse to think thats normal) and the ignition seems to work with all 4 ignition keys (has VATs) even thou 2 keys have square head and other two are round shaped all wrapped in plastic.The square ones seem to be abit longer than the other two but all work.Also the the plastic handles on the ignition switch (i dont know how is that called) are broken ...probably someone forced turned the ignition without a key.Even though it has VATs it also locks the steering wheel .
Car: 1983 Z28
Car: Firebird
Engine: 5737cc
Re: Number of keys
yea thats why I made this thread to know how many keys came with the car and if they were universal (door/ignition/trunk).I want to get the full set but the ignition switch i found is not black like the one in my car.Maybe sounds stupid but i want it to be black ,after all if I ship stuffs to europe I want them to be close to original as possible
Car: Firebird
Engine: 5737cc
Re: Number of keys
its a 88
so the square head ones are original and each had 2 normals ones.
On classic industries the whole set for doors and trunk have 1 key and if you want more you have to buy blanks ,and for some reason they are not goldish like the OEM ones.
Re: Number of keys
Goldish means the silverish plating has worn off.
Car: Firebird
Engine: 5737cc
Car: 91 TA Black & 91 TA White
Engine: LB9- 305 TPI
Re: Number of keys
I only remember getting two sets with the car from the dealer. However, you can have duplicate GM Factory keys still made at most GM dealers. I recently purchased a 1991 TA from a private party that only had 1 set of keys. It too a local Chevrolet dealer 1 day to get the right key in (They said there were 12 - 15 different ones) and 10 min to cut the key from the one I had.
Car: Firebird
Engine: 5737cc
Re: Number of keys
On classic industries for each lock they give a key thats not even goldish like the OEM one.Its interesting that they said there were 12-15 different ones ....get all 15 keys and you pretty much have all third gens around ...you dont share stuffs like that
Re: Number of keys
chevrolet
There are ALOT more than 12 - 15 keys around. There are 5 sets of blanks (A/B, C/D, E/H, F/G, J/K, where the first letter is the ign and the 2nd is the doors); however many VATS resistors, which is in fact some number in that range; then there are 5 pins in the tumbler, each of which has about 7 or 8 possible positions. This means that there are approximately 5 × 12 × 5^7 possible keys; since 5 to the 7th power is about 78,000, that gives about 4 million different possible key combinations for these cars. I'm not sure if they still used all the different letter combinations with VATS, so the actual number might really only be something around 1 million. Since all GM cars from 80-something to almost 2000 had the same kind of keys, there's probably only as many as about 15 to 20 cars that all use the same key.
You are seriously confusing BLANKS (the thing you buy at the hardware store, or what the car dealer has to order), and finished KEYS, which have the teeth cut in them. A BLANK will not turn a lock, only a KEY will. There may well be 12 to 15 different BLANKS with VATS, each of which is different because it has a different resistor; but then, there are 78,000 different KEYS that can be cut from each BLANK.
Axle/Gears: 10 Bolt 2.73 Open
Re: Number of keys
Wow...what a flashback topic. I used to do new car check-in for our dealership. I don't recall any cars getting more than two sets (not counting plastic cards meant to be carried in your wallet). Punched many sets of extras for salesmen that had sold a car, and the owner wanted extras.
Makes me sweat thinking about signing off paperwork for the truck driver, on the blazing hot hoods of dark blue State ordered Caprices in August. Ugh!
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Re: Number of keys
My red '88 GTA came with three VATS ignition keys and two oval door keys when I bought it new.
