overhead console...
Old Aug 1, 2007 | 07:00 AM
Bombero's Avatar
Car: 1986 IROC T-Topz Black/Black w/Gold Decals/Rims & Badges
Engine: 305 TPI stock
overhead console...
I have a 1986 T-Top and found a overhead console that I want to buy, is there a difference in the ones that were for T-Top and Non T-Top cars? If so can I modify the non T-Top to fit mine just in case it is the one I'm looking at?...I am pretty innovative and can make things work if need be, but if is a "round peg in a square hole" type of deal, I will pass...
Thanx...
Old Aug 1, 2007 | 07:40 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: overhead console...
Yes there is a difference.The t top console is flat whereas the hardtop console is curved to fit the roof line.Do a search as this has been covered many times before
Old Aug 1, 2007 | 08:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes, as my82 mentions. Check the following link for pics:
https://www.thirdgen.org/forums/faq-...oth-types.html
JamesC
Old Aug 1, 2007 | 10:06 AM
Bombero's Avatar
thankx guys for the info and the links, I got with the owner and he stated it came from an 87 with t-tops....Im going to get it....it even has the flashlight.
Old Aug 1, 2007 | 10:14 AM
JamesC's Avatar
If the seller has them, you'd be well advised to get the mounting pieces as well as a snippet of wiring harness. Purchasing them separately can be an adventure.
JamesC
Old Aug 1, 2007 | 04:49 PM
Bombero's Avatar
yeah, before I even asked for those he said he will throw them in....he knew more about it than I did.
Old Aug 8, 2007 | 05:38 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
I know one button turns on the little map light but what does the other one supposed to do? the button is fried on mine.
Old Aug 8, 2007 | 06:03 PM
JamesC's Avatar
Dome light. Shoot a bit of electronic cleaner around the button/switch and you'll probably be amazed.
JamesC
Old Aug 9, 2007 | 01:25 PM
redfire82's Avatar
Car: 84 camaro s/c
Transmission: TH400
JamesC
okany thanks, I took the button apart, its melted inside from the previous owner. Glad it's nothing neat though
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Jetmeck
Sep 4, 2015 12:29 AM
TheJoeY88
Aug 13, 2015 06:51 PM
DoBeR
Oct 16, 2001 05:00 PM
