Changing speedos/mileage
Old Sep 10, 2009 | 02:38 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I am in Australia and we use metric guages. I have just bought a set of metric guages from a 89 Trams am to swap into my car. My question is can I change the numbers to read the same as my old cluster?
Old Sep 10, 2009 | 03:27 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Changing speedos/mileage
I think there should be a way you can keep rolling the number wheel upward until you reach the correct mileage...
Old Sep 10, 2009 | 04:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you can remove the odometer mechanism from the guages and swap them. Its not hard, justa binch of screws. I've done it before
Old Sep 10, 2009 | 06:07 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
That's what I did a few years back when I swapped my stock 110 mph speedo for my current 145 mph.
Old Sep 11, 2009 | 03:08 AM
Sounds like that may be a winner. I will have a look when the new cluster arrives. Thanks guys I can always depend on this site.
Old Sep 11, 2009 | 11:22 AM
mikeiaz's Avatar
You do not say if your old cluster was metric or not, if not then your old odometer numbers will be in MILES not KILOMETERS so swap would not be accurate
Old Sep 11, 2009 | 01:00 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
you can remove the wheel and one by one set the numbers, it took me 15 minutes to match my mileage, alsop i dont think the number wheel matters for mile/kilos. i think there is adifferent gear ratio inside for the two thats it
Old Sep 11, 2009 | 05:33 PM
Should be getting the new one in a matter of days and will check it out. Will let you all know how it turns out. thanks.
Old Sep 12, 2009 | 10:25 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The early mechanical speedos are easy to adjust,....... Last winter I converted my step fathers dash to a full gauge set-up - it was a mechanical speedo and got converted to an electric Speedometer. Your car should also be electric.
I found it was easier to simply roll the odometer gears forward with a drill until I got the correct mileage showing on the odometer than it was to pull it apart and 'manually' change the reading by hand.
After setting the odometer in his replacement speedo to match his cars actual mileage, I re-set the odometer on another cluster all the way to Zero using the same method. ( The drill had a small rubber bit on the end of it. ) It took a LONG time to roll it all the way to '0' !!!
Old Sep 12, 2009 | 10:29 AM
Chevy8588's Avatar
my zero roll back to 10 minutes
Old Sep 12, 2009 | 02:34 PM
John in RI's Avatar
And that's why they don't make mechanical speedo anymore !
Old Sep 12, 2009 | 04:24 PM
My current one is in miles with little kilometers and the odometer is in miles. Can I switch into the new one the old odometer to read in miles? Or, will they not match?
Old Sep 13, 2009 | 02:11 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
So if I ever find a 145 mph cluster for my 92 RS can it be rolled back or reset to the mileage on the old original 110?
Old Sep 13, 2009 | 02:24 AM
From what I gather, you should be able to do either one. Or, maybe change your old odometer to the new one. That is the route I may go.
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
