crack around center a/c vent
Re: crack around center a/c vent
drill a small hole at the end of the crack, that will stop it from progressing any further
on a 87 iroc the pillar trim plastic pieces that fasten the trim to the body...i have checked gm parts direct .com and cannot find them...any suggestions on where i can locate these items...thanks
I found those white plastic clips on ebay. You mean those ones that slide into the pillar trim right?
The sellers name was pageautosupply and he has all those clips, also those X mas tree type things.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
GM dealer also usually has those pillar clips - they ain't cheap, think last set I got was $20, but they can ordr and get 'em.
Car: 1985 Z28
Engine: 305 LG4
That is a common spot to crack.
I repaired mine by removing the entire dash (big job) and using plastic epoxy and fiberglass mesh reinforcment. Not sure how long it will last, but I have put 2,500 miles or so on the car so far and all the repairs I did are holding together.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
In my case, I used a piece of 1/8" ABS plastic to strengthen the back of the dash. I used a toothpick to get some plastic epoxy into the crack itself, then made sure the crack was pressed together as tightly as possible, used more plastic epoxy to attach the piece of ABS to the back, then clamped everything tightly until the epoxy dried. Now the crack is almost impossible to see from the front, and is not expanding anymore.
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
