Stock autoshifter pics?
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I plan on putting the stock shifter back in my 1992 camaro eventually, and I found a shift plate on ebay for a reasonable price. I just need the shifter itself. I need pictures of the wiring and shifter from all sides if that's possible. Installed in the car, and maybe some pics of it not installed? I just want to make sure I get the right things with the shifter when I buy it or get it from a junkyard.
Thanks!
Thanks!
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: Stock autoshifter pics?
I may be able to help you. I took some pics when I did a neutral safety switch replacement. Ill have to find them on my PC after work today and see if they have what your looking for.
Thanks, im just looking for any pics of the shifter install and not installed, just to give me an idea.
Car: 1990 Camaro RS
If I remember correctly the pics would show the wiring to the shifter as well as the sfift plate, ****, and neutral safety switch removed. I didnt remove the entire shift assembly though I probably should. There is so much change in there its unbeleivable. I got as much out as i could reach there was actually a penny jammed under the shifter which was making it hard to switch gears. I still have the penny its all bent and torn up.
haha coins find their way into the weirdest of places...can't wait to see those pics,as they seem to be exactly what I need!
You mean the url for the ebay ad? I can't find the url right now.
Thanks! Do you happen to have any pics of the wiring connectors and stuff?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Not sure what shifter plate your looking at but correct for a 1992 would be yellow lettering which aren't easy to find.
THe one I found was off of a 1992 camaro rs anyway which is the same as my car. This guy is selling a lot of parts from his 1992 rs on ebay. Take a look!
http://motors.shop.ebay.com/tommygun..._from=&_ipg=25
This is what I'm looking at:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Linson
Aug 21, 2015 02:12 PM
