SPEEDOMETER
Old Jan 12, 2011 | 06:30 PM
RANDYH1's Avatar
Car: 92 CAMARO
Engine: 3.1
Transmission: auto
SPEEDOMETER
I need some help with my SPEEDOMETER . I installed a new speed sencer in the transmission and my speedometer trys to work some of the time. Any ideas where I should look to fix this problem.
Thanks Randy H
Old Jan 12, 2011 | 06:34 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: SPEEDOMETER
please go more in depth with the speedo working sometimes, does it seem intermittent, or with certain speed?
Old Jan 12, 2011 | 06:38 PM
RANDYH1's Avatar
Car: 92 CAMARO
Engine: 3.1
Transmission: auto
Re: SPEEDOMETER
It jumps around at speeds below 35 mph after I drive about a mile and then it stop working.
Old Jan 14, 2011 | 06:10 AM
RANDYH1's Avatar
Car: 92 CAMARO
Engine: 3.1
Transmission: auto
Re: SPEEDOMETER
Thanks Randy H
A little help please.
Old Jan 14, 2011 | 06:19 AM
9340Ruby's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 pos
Re: SPEEDOMETER
I am currently working on my 1991 Z28 with the same problem. I plan to work on it today. If I can help before someone else chimes in, I will. Good luck.
Old Jan 17, 2011 | 06:08 AM
RANDYH1's Avatar
Car: 92 CAMARO
Engine: 3.1
Transmission: auto
Re: SPEEDOMETER
Thanks Randy H
Old Jan 17, 2011 | 06:51 AM
puma1552's Avatar
Re: SPEEDOMETER
You'll probably get more help in Tech/General Engine or another tech forum since it's a mechanical problem originating under the hood or somewhere in the wiring.
This is a forum more for interior trim, etc.
Old Jan 17, 2011 | 11:22 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: SPEEDOMETER
I had this problem in my 88 GTA and it ended up being the gear on the tail shaft in the transmission. The clip that holds the gear in place broke and the gear would move when the car was in motion. To fix it you have to remove the tail of the transmission which is a pain.
The other problem could be the sensor motor itself it is easy to check though. Put a cordless drill on it and let her rip. If the speedo stays constant it is working fine if not there is the problem.
I would bet it is the gear on the tail shaft though. It took me the better part of four hours to fix mine in my driveway, but I was on my back with hand tools. You can get new gears and clips at any transmission repair shop for less than $20 combined.
Hope this helps.
Old Jan 17, 2011 | 04:23 PM
RANDYH1's Avatar
Car: 92 CAMARO
Engine: 3.1
Transmission: auto
Re: SPEEDOMETER
Hope this helps.
Thanks I will check that out.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
