Any Ideas why my turn signal switch won't stick to the right?
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
My turn signal switch isn't sticking to the right for some reason. It will to the left, but not the right. I have to go in to get the safty inspection sticker again, and I know they check this. The singal does work, it just doesn't stick. Any ideas?
Car: 1992 Camaro RS
Re: Any Ideas why my turn signal switch won't stick to the right?
I would like to figure this out soon so that i can go to the TGO meet on the 17th.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
that was my guess, stupid plastic breaks. if you talking about it staying to one side it is a broken return spring on the cam.
Car: 87 Camaro
Engine: 305 LG4 (H)
Probably the multifunction switch. To this day they are still going bad in GM cars.
Car: 1992 Camaro RS
Dang. It returns to it's nuetral position when I'm not using it, and it sticks to the left just like normal, but if I want to go right it WILL trigger the signal but it WONT stay there. I have to hold it in place and then it returns to its neutral position.
Engine: Lb9
Transmission: M20
looks like you will be pulling the wheel and getting a new switch.
http://www.ebay.com/itm/ACDelco-Part...#ht_1445wt_821
Car: 1992 Camaro RS
Aahhh crap. Hopefully the safty inspection guy will be leniant. I'll fix it eventually but I need other stuff done to it right now. How much would a new one Cost?
Engine: Lb9
Transmission: M20
depending on brand 25 to 50
Car: 1992 Camaro RS
Well thats not horrible, but it's not fantastic either.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
x2 on the multifunction switch, it was the problem with mine. Where do you get them? The only source I could find over here in Oz wanted over $200 for one.
The switch has a channel cast into it, in which guides a pin on the lever arm that actuates the blinker switch. The channel gets reamed out over time by the pin, and the lever arm can't quite get the travel required to click the blinker switch.
Not wanted to spend the $200, I actually managed to fix mine by building up the channel again with 'liquid metal' aka jb weld. Much better than having to hold the thing there by hand while turning, has worked fine for years now.
Also check that the screw that holds the lever arm down is not loose, will have the same effect.
Engine: Lb9
Transmission: M20
I posted the acdelco part number. you can go to rockauto.com to see other manufacture part numbers. Im sure a light part like that would be no more that 15 to ship to australia.
Engine: Lb9
Transmission: M20
np, if you need any help from across the pond let me know. cheers
Car: 1992 Camaro RS
Engine: LS1, LB9, L03
Be careful where you source it from, most of the non-GM ones are going to have the wrong finish or font color on them, and many of them are missing cruise control. I would expect to pay around $200 for a correct GM one if available.
Car: 1992 Camaro RS
Mine Doesn't have cruze control, which I already thought was fishy. Maybe it was already replaced with a crappy one, and that's why it doesn't work right. ?.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Probably because your car doesnt have cruise control. It wasn't standard equipment.
The obvious solution is to go to a boneyard and pillage one from another car. Most of them are good enough to work. And it will save you $190.
Car: 1992 Camaro RS
I don't know of any junk yards around here that carry allot of thirdgen parts. I'll just have to find somebody online who does.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Hang on guys, we're not talking about the same parts.
Navy - you are referring to the control stalk itself.
Tuneperformance - you are referring to the circular blinker switch that fits over the column - sorry the ebay link you posted did not have a photo, and I just traced the part number.
I was referring to the mechanical combination switch that the stalk plugs into. It actuates the blinker switch, high-beam switch, and wipers. This is the part that I had to fix.
Car: 1992 Camaro RS
Yup. That looks like the problem. Everything else on the **** works fine, but the switch doesn't stick when I turn it in to the right hand position.
Car: 1992 Camaro RS
I probably dont even need the wiring cause all that works fine too.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Check this thread out on pulling the column apart:
https://www.thirdgen.org/forums/susp...-steering.html
Post 1, 4th pic re-attached here - look at the number '3' - to the right and above that, is the screw that holds down a little black arm. One end of the arm has the pin that engages the channel in the aforementioned combo switch, the other end moves the blinker switch.
If this screw is loose, the arm won't be able to move the blinker switch till it clicks, same if the channel in the combination switch is worn too far.
Last edited by TreeFiddy; Dec 3, 2011 at 12:06 AM. Reason: added 'combination', too many switches in this thread!
Car: 1992 Camaro RS
Thanks man. Looks like another project to me haha. I need to get an owner's manual. I have a repair manual but I'm not sure it has all the info I need.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yeah, its a pita to get to. Pulling the column apart kind of forces you to acquire the right tools and swear heaps, but it's much easier the second time! Hardest parts are:
* Pulling the steering wheel. Will need either the right puller, or make something up.
* Depressing the lock plate. Need the correct compressor, or make something up.
* Sanity check whilst keeping track of where all the little parts came from, and the order in which they go back together.
Car: 1992 Camaro RS
yah. I'll have to just video tape it so I can remember which goes where haha.
I may need to do this when I go to fix my horn anyway, I don't know why it won't honk. It's a little seperated at the top and my friend thinks the air bag may have deployed. But that is another thread for another day.
