IGNITION KEY STUCK IN "ON" POSITION
Old Jul 20, 2014 | 07:03 AM
IROCZDAVE (88-L98)'s Avatar
Hello All,
*My car; 1988 IROC-Z Auto/Tilt Column
Its been a very long time since I have posted here.......
I'm having trouble with my ignition key sticking in the "on" position of late.
I was then able to turn the key slightly to the "start" position to get the key to turn off.
So I tried getting a new key made, that worked for a short time and I thought that was the issue......nope!
When it happened again yesterday I tired turned the key to the "start" position but now that no longer works!
I had to disconnect both the battery AND alternator to get the engine turned off!!!!!
So now I have to do some "trial and error" work to try to figure out what the problem is.
Does anybody have any experience with what it could be???????
*Cable interlock from the shifter?
*Ignition cylinder?
*any other steering column components??????
Dave
Old Jul 20, 2014 | 07:50 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: IGNITION KEY STUCK IN "ON" POSITION
My pickup just did the same thing (tilt/manual). A little unnerving when you can't shut the engine off, plus I had to leave the key in it overnight too.
I noticed that the key I was using was worn and was thinking about having another key made because of it. Looks like I'm replacing the cylinder lock for sure now and that's what I'd suggest. I really don't want to drive around with specially tools and/or get stuck far from home with that happening again.
I haven't called any dealerships yet, but when I looked online it looked like they didn't carry lock cylinders for tilt columns, but some after-market stores carry AC Delco for $40 vs the $20 for the other lock cylinders. I was wondering if there is any quality difference or not.
You basically use a couple of tools. One to pull the steering wheel, and the other to push in a plate to take a snap ring out. Then it's pretty easy to get to the lock cylinder and replace it. There are good videos on Youtube for that as well
Old Jul 20, 2014 | 10:47 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
replace the lock cylinder. you can 'rent' the puller and lockplate remover from AZ or one of the other chain parts stores.
Old Jul 20, 2014 | 01:49 PM
Thanks for the quick replies everybody!
I'll do just that, replace the lock cylinder.........
I believe I have all those tools here handy for the job.
Thanks again guys!
D.
Old Jul 20, 2014 | 04:41 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Yup, happened on my old 88'. At a gas station key got stuck in the column couldn't get it out. Had to call a lock smith to replace the ignition cylinder. The pins inside the tumbler got out of whack and actually wrapped around the teeth on the key...
Old Jul 20, 2014 | 05:02 PM
Ouch (MEENZ28), that was most unfortunate.......
Luckily my lock cylinder decided to lock up on me at my home just before taking it out for its weekly drive.
I have had my column apart some years ago when I had to tighten up the tilt mechanism as it was somewhat loose (I wrote an article about it and I believe its still posted here?) so this procedure should not present too much of a challenge.
I checked out some videos on You Tube just to confirm what was involved.
I also DO have a Factory Service Manual for my IROC as well all the necessary tools so I believe I'll be ready to dive into this when the parts arrive on Thursday.
I managed to find a brand new AC Delco MATT BLACK Lock Cylinder with 2 GM keys on Amazon.com for $18.00 shipped. (At the time there were only 5 units left in stock)
Tried all the local auto parts stores and the only AC Delco/GM units they had in stock were chrome plated ones, nope not for my IROC!
I have attached a current photo of my 88 IROC to this message, I hope it shows up!
Thanks again to everybody here for the help and advise, its good to see that these forums are still worth visiting when I need a little help!!!!!!!!!
Dave Staubli, Third Generation USA (aka IROCZDAVE)
Attached Thumbnails IGNITION KEY STUCK IN "ON" POSITION-my-1988-iroc-7   IGNITION KEY STUCK IN "ON" POSITION-my-88-iroc-rear
Old Jul 20, 2014 | 06:57 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Same thing happened in my daily driver (2006 Saturn Vue), after searching it was common issue with those cars (GM lol).
Luckily, I was able to move my key back to "accessory" so the car would shut off, but the radio and lights were sticking on. I, like you, also have to disconnect the battery and leave the key inside over night. Anyway, I drove it around like that for a week and disconnecting the battery every time I had to stop lol. Took it too a mechanic the following weekend (started on a Sunday) and they replaced the cylinder.
He took it apart and greased it up and it was "working" but the key if you didn't pull it our fast/hard it would get stuck halfway coming out. So I went ahead and replaced everything just to be safe.
Old Jul 20, 2014 | 07:47 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
For future reference, I had this problem too but it actually wasn't my lock cylinder.
It was the rod had got caught on the plastic sleeve that wraps around the column.
Where the column goes under the gauge cluster, there is a plastic cover, and you can turn it round and round. I found that by moving that plastic, my ignition became unstuck
Old Jul 20, 2014 | 10:09 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Good idea to check that rod while the lock cylinder is removed.
I was on my way to an OZZ-Fest concert one year and stopped for sandwiches on the way. Had my ignition act exactly as you describe. After crawling under the dash I found the rod would not move - it was somehow stuck inside the little "Ignition Box" at the base of the column. Lossened the "box", then pinched the rod with pliers pulled it till the starter kicked - and got to the show on-time !!!
With the ignition cylinder remove I'm pretty sure the rod can be gripped with small vice grips/pliers and moved "manually",...... if that rod doesn't move, the box at the base of the column might be to blame.
Good Luck !
Old Jul 21, 2014 | 07:10 AM
Very good info guys!
I will indeed check the rod while I have everything torn apart!
I checked my service manual and the key lock cylinder replacement is simple once you get past the wheel, lock plate and finally the turn signal switch.......
I'll also check those tilt mechanism bolts as well........
Thanks again!
D.
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Make sure the cable that runs from the shifter to the column isn't in a bind. Mine has done it sometimes and if the car doesn't think it's in park then it won't let you shut it off.
Old Jul 21, 2014 | 12:09 PM
OK!
TEHSOCKS; I checked my plastic sleeve and it does NOT rotate!
I dropped the column and visually checked and it seems my sleeve is locked in place.
Both the ignition AND dimmer switch rods move freely and show no signs of binding.
I now believe/hope that it could very well be the key cylinder.
REDLEADER289; How would I go about checking the cable from the shifter to the column, I have removed my shifter plate and I can see the end of the cable itself but I have no idea how it runs to the column?????
Old Jul 21, 2014 | 12:27 PM
Car: 1983 Z28
The cable is connected to the rotating sleeve on the column, just make sure both move freely and you're good.
Old Jul 21, 2014 | 12:31 PM
naf's Avatar
naf
the cable interlock prevents the key from being removed when the trans is not in park. it does not prevent the ignition from being turned off.
Old Jul 21, 2014 | 07:07 PM
OK "redLeaser289"
So if "NAF's" statement is correct then the auto shifter cable has no effect on the key lock cylinder not being able to be switched to the off position.
Are we in agreement here?????
D.
Old Jul 22, 2014 | 07:32 AM
Car: 1983 Z28
Ok, yeah. I forgot that you couldn't switch it to the "off" position. I was thinking that you couldn't turn it to the position that allows you to take the key out, my bad.
Old Jul 22, 2014 | 09:16 AM
No worries!
I appreciate every bodies help and opinions in this matter and will be tackling this key lock cylinder replacement towards the end of the week.
I'll update this posting after finishing up (hopefully).
Thanks again guys!
Old Jul 24, 2014 | 04:35 PM
Scorpner's Avatar
Engine: V6, V8
All that glitters is not gold. I had a surprise waiting in store for me.
(I picked up a new lock cylinder from a local dealership btw.)
Old Jul 25, 2014 | 07:10 AM
Car: 1983 Z28
Oh wow!!
Old Aug 5, 2014 | 09:03 AM
Re: IGNITION KEY STUCK IN "ON" POSITION (REPAIRED!)
Hey guys,
I have successfully replaced the ignition key lock cylinder and I no longer have any issues with the ignition key turning to the "OFF" position!
I also re-tightened my tilt joint bolts while I was that deep inside of the steering column.
Thanks again for all the input/advise.............
Old Apr 24, 2020 | 12:36 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Same issue here. Just tried to turn on my Camaro. Been having trouble starting (possible bad ignition switch). So I went out to turn it on. No crank. As I turned the key back to remove it, the lock cylinder would not turn back to the off position. Luckily my key is so worn that I pulled out the key and disconnected the battery. So tomorrow, I'm off to buy a new ignition switch and a new key cylinder.
Old Apr 25, 2020 | 12:09 AM
Fixed my issue. Ended up being a bad ignition cylinder. swapped out for a new one and now it's good to go.
Broken inner collar.
George Klass
Apr 9, 2017 03:32 PM
Kandied91z
Dec 18, 2004 03:40 AM
knightjacob
Jun 18, 2003 03:13 PM
BenDoe91z28
Nov 1, 2002 02:48 PM
novamatt21
May 1, 2002 11:19 PM
