Upholstery cleaner?
Old Apr 16, 2018 | 08:38 AM
onebdgti's Avatar
Upholstery cleaner?
Does anyone have any good upholstery cleaner. My car has been sitting for 5 years and the carpet and seats are nasty.
Old Apr 16, 2018 | 08:50 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Upholstery cleaner?
It doesn't;'t matter what I've got to clean,.... Bucket of water and a bottle of "Superclean",... If it will 'come out' - that's all you need, Superclean will remove anything other than permanent stains.
Old Apr 16, 2018 | 09:01 AM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
I use diluted thieves oil in a spray bottle, its works and it doesn't have any crazy chemicals in it, it smells good too.
Old Apr 16, 2018 | 09:18 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Barbasol shaving cream works well. Use a soft brush to work it in, let it dry, and then vacuum. It's really just soap in a can.
Old Apr 16, 2018 | 02:22 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I’ve done this and it worked well for me.
Old Apr 16, 2018 | 03:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Resolve works well for those carpet stains. But I agree with John superclean rocks.
Old Apr 16, 2018 | 03:42 PM
Drew's Avatar
Tuff Stuff works pretty well. I've used the Bissel household carpet/upholstery cleaner machine with warm water a few times in the past. You wouldn't belief the filth you can extract from the upholstery.
Avoid cleaning the headliner, rear speaker covers, or sunvisors. The foam backed fabric will usually have deteriorated a bit, and if you so much as touch it, it'll leave a divot and the fabric will wrinkle and fall loose.
I also wouldn't put any cleaner on exposed upholstery without first testing it somewhere that you won't mind if it bleaches the cloth.
Old Apr 16, 2018 | 03:47 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Amazon Amazon
I bought this a few years ago and love it. I've spilled dark red wine on white-ish carpet, went and pulled this out and it cleaned it perfect. I use it on cars and all interior upholstery. With two little kids I find myself cleaning the couch every other month. I fill one tank with water and super clean or another detergent and go to town. After a vacuum its the best cleaning tool I've bought.
Old Apr 16, 2018 | 09:35 PM
onebdgti's Avatar
Thanks guys I have a carpet cleaner here I am gonna try on the seats and carpet. i read somewhere online about using oxiclean and dish washing soap. Has anyone tried it?
Old Apr 17, 2018 | 12:08 AM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Resolve and a shop vac can work wonders..
Here’s a car I did recently
Trick is to brush it in with water and suds up, let it sit for a few minutes.. then take a damp terry towel and distress the stains more.. suck up the water with a wet vac and let dry.
Any remaining stains, use a little spray and a damp terry towel.
For carpets just spray, brush with water and work in, then extract with a wet vac..
Similar to extracting with a rug cleaner.. the lubricity and distress loosens grime so it can be sucked up into the vac.. get a scrub brush and a smaller brush for nooks like this..
I’ve used diluted cleaners like superclean as well but find resolve works really well and is safe on anything I’ve done..
You don’t need to use too much water either.. car should dry quick after running heat for a few..
Old Apr 17, 2018 | 08:15 AM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Murphys oil soap
Old Apr 17, 2018 | 09:23 AM
Axle/Gears: G80 GU2
I’d be careful mixing things like that. Also dish soap will strip the fibers of any stain fighting ability that they have.. It might be ok for oil or grease spots, but most carpet cleaners can remove that stuff more safely. Oxi Clean makes a carpet cleaning product, looks like mostly for spot cleaning..
Carpet cleaner a scrub brush, a bucket of water, terry towels and a shop vac can make rugs look brand new..
I wouldn’t mix products but the idea of each product is the same, loosen the stains, dirt, hair, dust, etc and extract it..
Old Apr 17, 2018 | 01:58 PM
onebdgti's Avatar
Thanks I will remember that. I have a great wet/dry vac that I can use. Thanks for all the help
Old Apr 17, 2018 | 04:40 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
my brother swears by this stuff, I've seen it get some pretty impressive stains out as well
https://www.dollargeneral.com/blue-m...iABEgLF_PD_BwE
ĦMR.AWESOME!
Mar 25, 2008 07:32 PM
llvll4l2c91350
May 2, 2004 01:47 PM
Zrated83
Jul 27, 2003 12:51 PM
speeddevil
Oct 9, 2000 10:36 AM
