Dashboard Vibrating Noise
Old 04-02-2024, 08:23 PM
ESP1138's Avatar
Car: 1992 Pontiac Firebird Trans Am
Engine: 350 c.i.d. (5.7L)
Transmission: automatic
Axle/Gears: RWD 7.75" axle 2:77, 3.27 gears
Hello to all Thirdgen enthusiasts!
As my first post, I want to ask about something that has been bugging since the first day that I owned my F-bird. There is a rattling sound near the center of the dashboard every time I drive my car. I have no idea what causes it nor how to fix it.
Has anyone ever had this problem?
Any advice?
I bought my 1992 Firebird in mid 2005. It still needs plenty of maintenance. I wish I were a mechanic.
Old 04-02-2024, 10:25 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Dashboard Vibrating Noise
Yeah bud, no idea what is rattling on your 32 year old car. My advice is start looking for what is rattling.
Old 04-02-2024, 11:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Rattling is a standard feature in most every 4rd gen. Removing the dash pad and driving it might help determine the source. Thats where id start.
Old 04-03-2024, 12:10 AM
Airwolfe's Avatar
Location: Franklin, KY near Beech Bend Raceway, Corvette Plant and Museum.
Engine: 5.0L L03 TBI
As my first post, I want to ask about something that has been bugging since the first day that I owned my Firebird. There is a rattling sound near the center of the dashboard every time I drive my car. I have no idea what causes it nor how to fix it.
Man I really wished you would have posted this yesterday on April 1st.
Not that I know of. No one in the history of owning 1982 to 1992 3rd generation Camaros or Firebirds has ever had a problem with interior squeaks, rattles, moans, or groans. The 3rd gen F-body are some of the finest cars GM has ever built. The build quality is almost on par with a Bentley or Rolls Royce.
Any advice?
With the vast amount of clues you have given us to work with my advise would be to Ask Miss Cleo.
You and I are lucky to both own 1992 Firebirds. The late 91 and all 92 Camaros and Firebirds are the best built and tightest 3rd gen F-body cars GM ever built.
Firebird Quality Now Initiative.
Facebook Post
Facebook Post
You don't need to be a mechanic to find your rattle. You need to be a detective. You might need to be a mechanic to fix the rattle.
For us to figure it out for you with absolutely nothing to go on we would have to be mind readers and magic.
Note: My reply is mainly sarcasm and I'm pretending you posted this on April Fool's Day for the LOLz.
Old 04-03-2024, 05:44 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I bought some felt tape on Amazon and put it pretty much everywhere in the dash where plastic touches plastic (if possible). Also where the steering column rubs against the plastic, and where the dash pad rubs against the A-pillar trim. It did help somewhat.
The following 2 users liked this post by 80schild:
DynoDave43 (04-04-2024), ESP1138 (04-03-2024)
Old 04-03-2024, 07:37 PM
ESP1138's Avatar
In that case, never mind. I was hoping someone out there had a similar issue and an easy fix.
I am beginning to think that maybe those A/C vents might be the problem, though I am only guessing.
Old 04-03-2024, 08:07 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
You can almost point at a spot on these cars and you will most likely find a squeak/rattle/groan or some other noise. Sometimes the cause is under the hood or from the suspension that transfers into the interior. Different causes can reveal themselves at the same spot inside the car.
Basically what i'm saying, is its kinda hard to tell you what's causing the issue or where its coming from. As mentioned you gotta play detective somewhat. The usual suspects are loose/missing screws, broken/cracked plastic joints, various parts rubbing/vibrating together and other things i cant think of right now. You just gotta put your nose to the grind stone and find/fix or just live with it.
ESP1138 (04-04-2024)
Old 04-04-2024, 11:32 AM
ESP1138's Avatar
Thank you everyone for all of your input.
Old 04-04-2024, 11:50 AM
Airwolfe's Avatar
You could try taking the cardboard tube at the center of a roll of paper towels and holding it to your ear and pointing it around to where you think the noise is coming from and seeing if you can pinpoint the source of the rattle. Of course only do this while you have a friend driving the car around.
Old 04-05-2024, 05:35 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Don't rule out the windows either. My car is dead quiet with them down but rattle city when they're up. I'm pretty sure it's an issue with the guides not being adjusted correctly but I'm waiting till I get new door cards and top rails to take it all apart and fix it.
Crusin' 1980's
05-18-2011 09:54 PM
dopplereffect
01-22-2004 10:02 AM
ViciousZ
07-27-2002 03:11 PM
Quick Reply: Dashboard Vibrating Noise
