wanna test a ls1 before buying? urgent
Old Apr 30, 2012 | 04:39 PM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
i found a complete 98 camaro ls1 for cheap the guy says the fuel pump is bad but i wanna hear the engine run before i buy it it has overr 177 k on the engine
is there any way i could hook up a fuel pump into a bucket of gas an then connect it to the engine to just fire it up ?
Old Apr 30, 2012 | 04:56 PM
blakecharles's Avatar
Re: wanna test a ls1 before buying? urgent
uhh... I'm going to assume it has the full harness and PCM....
supply the proper power and grounds (see your fuse box + starter), fuel pump in a bucket... I'm also guessing your not going to use coolant... DON'T LEAVE IT ON FOR LONG!!!
also, do your own homework... don't trust mine. All the above seems like more then it's worth. I would say, pull the valve covers and oil pan. check that bottom end out. if it's okay... go for it.
got my 98 LS1+T56, ls1 tank, harness, pedals and some other stuff for only $1750.
Old Apr 30, 2012 | 05:02 PM
Transmission: auto
its a entire car the engine is in the car along with everything but were would i hook up the fuel line and would i need a high pressure fuel line to hook up and the pump needs to put out like 45 psi if i remember
Old Apr 30, 2012 | 05:34 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
If it was me, and the price was right, I would just buy it as is. Your going to be rebuilding the motor anyways I would hope. As long as the price is right I say just go for it.
Old Apr 30, 2012 | 05:46 PM
Transmission: auto
the guy wants 1500
Old Apr 30, 2012 | 06:02 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
go for it bro
Old Apr 30, 2012 | 06:13 PM
Transmission: auto
no one has answered my question can i take a fuel pump put it in a bucket of gas and hook it up to the fuel rail and start the car lie that ? i just want to here it run
Old Apr 30, 2012 | 06:50 PM
Yea you can do that. Just make sure the pump puts out the proper psi for the engine. For $1500, I would take that in a heartbeat!!
Old May 1, 2012 | 12:05 PM
torque_is_good's Avatar
sure there is a way
the sell price is $1500
what you aren't taking into account is the seller can tell you to take a hike
if it only needed a fuel pump the seller would put one in and sell the car for over $4,000 unless of course it's wrecked?
You can cut a hatch and replace a 4th gen fuel pump with relative ease.
Old May 1, 2012 | 08:10 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
dude that's a lot of hassle for a car this is being sold for cheap. You are going to need a High pressure external pump, fuel line, gm quick connect for fuel rail, Corvette regulator, wire, and a fire extinguisher for when something effs up and burns the car to the ground.
Ps you will look like a super retard showing up with all this crap asking to see if you can get it to run.
Old May 1, 2012 | 10:08 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
$1,500 for the complete car? Buy it. End of thread.
Old May 1, 2012 | 10:54 PM
Old May 1, 2012 | 11:02 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
dude..spray quick start in the throttle body and crank it over.it will run for a second or 2 max.
even still,id buy it just for all the other parts you would need incase the motor is still blown.the fbody ls1 accessories,the trans if its m6,wire harness,interior etc etc
Old May 2, 2012 | 12:08 AM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
No doubt. If the car was close to me, it would be SOLD!!!!
Old May 2, 2012 | 08:11 AM
vwdave's Avatar
If I was selling a car for $1500 and you showed up with a bucket of gas and a external fuel pump I would tell you to leave. Either buy the damn car or leave the guy alone.
Old May 2, 2012 | 08:54 AM
I said the same thing but a little more diplomatically. The red flag here is that if it really is just a fuel pump why wouldn't the seller replace it and get it running so he could get $3,000 more for the car?
But, on the flip side, a complete LS1 4th gen for $1500 even if the engine is shot is a good deal and chances are the OP is young and doesn't realize it's one of thoe things in life you jump all over. Experience will teach him that as he matures.
It's like the new leather interior you find for $250 and rush to the forum to ask if it's a good deal instead of buying it immediately.
Old May 2, 2012 | 11:58 AM
vwdave's Avatar
Im just a jerk really.
Then again, Ive done the same things when I was younger.
Old May 2, 2012 | 01:32 PM
nah, I wouldn't say that. To those with experience we look at things like a $1500 complete LS1 car as a no brainer. Heck, go to the exhaust section and read the threads hemming and hawing over a $200 set of headers.
We tend to forget what it was like when everything we did was for the first time.
Old May 8, 2012 | 11:53 AM
this guy isn't going to let you hook all this stuff up. 2 ppl here told you what to do to start it... and EVERYONE told you that it's not worth the hassle.
what else do you need to know?
Old May 9, 2012 | 01:06 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ide be buying that thing quick. No hesitation. Heck even being broke as a joke Im thinkign to myself that I would find a way. Even if you just turned around and parted it you'd see a nice return on your investment. Unless its wrecked or stolen like previously stated.
Im assuming he's advertising it somewhere? If you dont ****** it up...someone else will!
J.
BRoss99
Aug 10, 2025 05:08 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
