91z with LS1 stumbling when you give it gas?
Old May 1, 2012 | 05:08 PM
kyrenegade's Avatar
Car: 91 Camaro Z28
Axle/Gears: 3.42 Posi Disc
I have a 91Z28 with a Ls1 and 4l60e tranny. The problem I am trying to figure out is when I give it gas in first gear. The car stumbles for a few seconds then takes off like a bat out of hell. If I try to acelerate slow it stumbles worse. But if I lay into it slightly it stumbles then takesoff. Fuel pressure is at 58 psi. Dont have any codes showing on the scanne.
Does anyone have any ideas to try or thoughts?
Thanks,
Chris
Old May 1, 2012 | 06:48 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: 91z with LS1 stumbling when you give it gas?
TPS might have a bad spot on it.
Old May 3, 2012 | 01:47 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Misfire?
Pleaaaaase change your profile. An LS1 is a 346 not a 350.
Old May 3, 2012 | 03:48 PM
kyrenegade's Avatar
Car: 91 Camaro Z28
Changed the TPS last night. Didnt help the prolem any. Oh well, one less thing to think about. Lol!
Old May 4, 2012 | 09:29 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
is it running rich? i havent hooked my 02's up yet and it does the same thing when idling and leaving from a stop from being overly rich from lack of the sensors.
Old May 11, 2012 | 10:48 AM
kyrenegade's Avatar
Car: 91 Camaro Z28
Tried the Throttle position sensor. No difference. Hooked a scanner up to the PCM (ECM) and it gave me a code PO134 O2 sensor no activity. I did a scan while idling and found this information.
O2 sensor Bank 1 sensor 1
Rich lean threshhold
Max-----V ?
Meas 0.365V
Min-----V
Mod $10
_________________________
Lean Rich Threshold (Same as above)
Lo V for switch
Max----V?
Meas 0.300
Min ----V
Mod $10
Hi V for switch
Max----V
Meas .600V
Min----V
Mod $10
Rich Lean Switch Time
Max .24s
Oxygen Sens Mon - Inc
Oxygen Sensor Heater - Inc
O2 S11 V .570-.595
O2 S12 V .440-.445
O2 S21 V .585-.730
O2 S22 V .440-.450
Fuel Rail Pressure 55-56 PSI
Is any of this information helpful to diagdose this problem? Hate to spend money just swapping out O2 sensors if its something else!
Thanks for your help!
Old May 11, 2012 | 11:27 AM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Which injectors do you have? Stock 28 or ford. I had a set of ford 39 lb injectors and I had shitty idle and the same problem as you have. I changed it out to stock vette injectors and now she is fine.
Old May 12, 2012 | 10:15 PM
kyrenegade's Avatar
Car: 91 Camaro Z28
I dont know which I have? I will have to check and see. Thanks for the advice!
Old May 13, 2012 | 03:31 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Sounds like a fuel pressure problem under load to me. Do you have a manual gauge you can hook up to view the pressure while driving?
Old May 13, 2012 | 08:04 AM
RockJay81's Avatar
http://www.youtube.com/watch?v=BdQeA...5&feature=plcp
its the spray pattern for the ford injectors. hopefully you dont have these try to pull one out and take a pic of it or take a video of the car at idle and driving. good luck bro
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
