T-56 Shifter questions Auto to Stick
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
I admit this my first time shopping for a shifter woundering and i know any shifter is a upgrade over stock
been searching googling reading comparisons
what you T56 guys are running ???ive been searching on here to see if anyone is running Hurst Billet Plus i like how you can adjust the tension on them ... other ones ive been looking at is MGW on bad is 5th&6th gear wont center correctly and also the Pro 5.0 only bad is that its noisy other option was just get b&m ripper used market and try out skip5-6.com kit for the time being and upgrade later
any info would be helpful
Engine: 305 to 350
Axle/Gears: 10 Bolt
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: T-56 Shifter questions Auto to Stick
Attention to Detail thats been drill to my head lol
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Running a Pro 5 and have no issues or noises.
How do you make it better ... run a Tick Performance master, then shifts like lightning, without missing any shifts.
I was shifting my 406 at around 5600 with LS1 master drill modded and Pro 5. Odd shift missed/ground from 2nd to 3rd.
Now with the LS1 and shifting at 7000 with a Tick master and it feel like a completely different tranny. Awesome combo and I don't feel I am giving away too much time to an auto.
Engine: 305 to 350
Axle/Gears: 10 Bolt
tick is very nice piece ...
yea majority of issues with noise has been from ford guys and ls1tech thats the only reason i brought it up lol
hows pro5 for daily driver idk if you guys drive it alot? i drive atleast 300miles a week....
prob just adapt and overcome type thing
what is LS1 master drill modded and what does it do ?
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
hurst billet plus....great shifter, no complaints. very positive feel, and great craftsmanship.
i've always been a hurst guy though....all of my standards have received a hurst shifter.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I love my Pro 5.0, but I think at this point "best shifter" is mostly subjective. is there any way you can go play with a few?
Engine: 305 to 350
Axle/Gears: 10 Bolt
it is a subjective tho im not looking for the best really as every body has there opinion
was just asking about the hurst due to ajustability tension as compared to MGW, and pro5 where you cant really adjust the tension ive heard good things from all 3 no big pressing issues really with any of them
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I have a hurst pro billet, but I never adjusted the tension on it. I think it feels fine the way they send it. I do have the instructions for it and can read how to do it if you want.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Pro 5.0 with custom rubber gasket and factory rubber boot cut NEATLY around the shifter. Zero noise and I loved it as a daily driver. You can tinker with the recentering stiffness, modify/swap the shifter handle, and you can leave the shifter base on if removing the trans unlike with a b&m. Just my likes...
MGW would be my next choice if I ever make a move.
J.
J.
Engine: 305 to 350
Axle/Gears: 10 Bolt
i seen the instructions online ist it notchy like the pro5 and mgw whats your review on it i guess in general ? and compared to others
Engine: 305 to 350
Axle/Gears: 10 Bolt
how do you tinker with recenter stiffness did searching but only found that some people got hurst springs etc. to do this or does it come with extra? website for pro 5.0 isnt that good imo for info lol
J.
J.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Are you pro 5 Guys having difficulty shifting 5th and 6th like mgw
Car: 1992 Camaro RS
No. I don't have any trouble with anything with my Pro 5.0. No complaints at all.
Car: 86 Trans AM
As for the 5 - 6.. Never had any issues. Thats a slow shift. I dont make a habit of WOT super fast shifting from 5 to 6. Usually run out of road or nerve at the top of 5th. But its always been nice 1-6. Button on the shifter **** makes the reverse lock out function nice and smooth. I love it.
J.
Car: 91 Z28
Engine: 6.0L LQ9
here in northeast kansas there most of the roads have too many curves to bottom 5th or 6th out.
Engine: 305 to 350
Axle/Gears: 10 Bolt
You remove the two bolts that contain the centering springs and shim them. With washers or bolts. Its pretty easy. I have a couple small shims on one side only to get the left to right snap a little better.
J.
J.
wow thats pretty harsh lol but sounds like the roads are fun to drive on
Car: 1992 Camaro RS
T56 5th and 6th gears arent meant for high power anyway. Theyre not as strong as the 1-4 gears.
Car: 86 Trans AM
Ive stretched 4th and slow shifted to 5th and stayed in it for a little. But its not something that happens often. Rarely Ide say. 1-4 is all the fun I need!
As for the shifter with button...Its a Hurst white ball with a 6 speed pattern and button. The reverse lock out solenoid is simple. Give it 12 volts and it lets you go into reverse easy as pie. So its just a simple switch hook up between the shifter, solenoid and power.
J.
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea i seen people miss 3rd and go straght to 5th trans didnt really like that lol
intresting ...
intresting ...
Car: 86 Trans AM
No idea how they do that. 2-3 is palm on shifter and shove it into the radio pod. Especially easy with a good shifter that snaps to center. Missing third and going to first is common because your arm wants to pull towards you some. People get excited and loose focus and pushrods and valves feel the effects.
J.
Edit...forgot I made this. Shows my shifters movement and the reverse lockout function. This is after I shimmed it I believe.
J.
Engine: 305 to 350
Axle/Gears: 10 Bolt
they was using stock very worn out shifter
ill check it out when i get home
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I also like the Hurst billet plus. IMO the Pro 5.0 is overated. I think they shift pretty notchey. But some people like that. The MGW has to many fail points IMO. I like the kiss method. The way it bolts together just looks destined to come loose at an inoportune moment.
Engine: 305 to 350
Axle/Gears: 10 Bolt
lol you have the hurst or pro 5 ? the hurst is less notchey or slight difference?
Car: 93 240SX
Engine: LQ9
https://www.thirdgen.org/forums/ltx-...dnt-i-get.html
That first post sums it up.
Those who didnt like the Pro5 were probably married, and hanging out with their wife too much.
Engine: 305 to 350
Axle/Gears: 10 Bolt
just wanted input on hurst billet as not many people are running
ive research and search and heard nothing bt good from all shifter mention in OP
lol what you trying to say im married and my wife occasionally surprises me with parts i want and she gets all greasy and dirty puttng them in with me
so i guess im in the category of hanging with my wife to much
DAMN
that actually made me giggle a bit tho
DAMN
Car: 93 240SX
Engine: LQ9
DAMN
DAMN
Engine: 305 to 350
Axle/Gears: 10 Bolt
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Id like to comment on the hurst but Ive never driven a car with one.I got 0 complaints about my pro 5.0 as I mentioned in the above thread.I have 0 noise since my car was already dynamated when i did my initial swap to 6spd and I have a light layer ontop of the rubber boot just to keep the tans heat out of the cabin.I dont think there would be any difference between the hurst and 5.0 to be honest I think it boils down to the installation.You wont be 100% on the frist try untill you bang a few gears and work it in..then readjust.Noise is all in your head and some have high tolerence and some dont..I dont lol.Have not heard bad things about either one..just the brand nut swingers who overly promote them.I have heard a few issues with mgw but nothing that has been really documented to worry about.To me its a very pretty and expensive shifter that is more bragging rights than funtionality so far.Id want some hard seat time to change my mind over any other decent shifter on the market.
Engine: 305 to 350
Axle/Gears: 10 Bolt
