LY6 carnage
Old Mar 6, 2022 | 01:38 AM
  #201
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
Originally Posted by obeymybird
Not much going on over the winter so far but thats about to change! Got a smoking deal on this unit which has new bearings a Eaton coupler and zero rotor damage for $1,000 just need to grab a hub and pulley combo.
It is amazing what a very small displacement Supercharger (High-Helix or Twin-Screw) can do today!
Old Mar 13, 2022 | 11:27 PM
  #202
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
Seriously though; The LSA High-Helix Supercharger has a roughly 1.8L Displacement...
Thats is TINY compared to Superchargers of "Yester-Year"!
It is WAAAAAAY smaller than a 6-71 Supercharger!
Although the 3-Lobe Roots Design is horrible compared to the LSA Blower.
It is even smaller than a 4-71 Supercharger!
Those 142/ 144 Weiand (Single Carb Style) Superchargers are a 2-71 Size...
The LSA Supercharger is STILL SMALLER!!! ...at roughly 110 Cubic Inches (compared to 142 or 144 Cubic Inches).
If the LSA Blower used the Screw Design instead... it could potentially be even more efficient!
Old Mar 14, 2022 | 07:22 PM
  #203
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: LY6 carnage
It should work great and give me a better all around driving car least thats the plan.
Old Mar 14, 2022 | 09:20 PM
  #204
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
Absolutely!
They are great little Superchargers!
My 1992 Track Only Camaro has a 4.0L Spercharger (like your LSA Blower, just larger) that should have a ridiculous Torque Curve (or lack there of! should be a very High Flat Line instead)!
I have to decide on a Rotor-Set for the Blower.
I am not sure if I will go with a Screw Design from PSI or Whipple...
Or a High-Helix Design from Eaton.
Old Mar 20, 2022 | 09:26 AM
  #205
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
That thing should make some power!
Old Mar 20, 2022 | 09:30 AM
  #206
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Finally got this thing pulled. Going to clean up the bay some then start the 6.2 full teardown. I have a monster twin disk that’s going to be for sale with lightened flywheel with less then 5,000 miles on it if anyone is looking.
Old Mar 26, 2022 | 03:44 PM
  #207
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Pump showed up yesterday so going with the green spring for some extra oil pressure.
Old Mar 26, 2022 | 07:26 PM
  #208
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Got fresh oil in the blower today along with getting the new hub pressed on. Was stuck on which upper pulley to go with between 2.55 or 2.45 so split it and got a 2.50.
Old Apr 1, 2022 | 09:57 PM
  #209
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
6.2 pulled apart about ready for a fresh hone then hopefully going right back together.
Old Apr 1, 2022 | 11:31 PM
  #210
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
It may be the Image...
But the Main Bearings do not look too good.
Old Apr 2, 2022 | 07:29 AM
  #211
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Yep the LSA engines are very hard on the rod and main bearings. The cts-v forums are full of spun bearing posts and I have new king bearings on stand by.
Old Apr 16, 2022 | 10:10 PM
  #212
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Some more progress almost time to go back in the car.
Old Apr 16, 2022 | 11:59 PM
  #213
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
Did ya spend $30 on a set of Bearings?
Old Apr 17, 2022 | 07:03 AM
  #214
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
More like $150.
Picking up a pilot bearing and front cover seal today then I can button up the bottom end.
Old Apr 17, 2022 | 07:54 PM
  #215
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
When I started kicking this build around in my head I knew there was going to be a few big money parts that was going to hurt the wallet but so far I got most of them bought and got a decent deal since I creep on several other forms.
Needing a 8 bolt clutch hurt since my moster twin is basically new still and a new 8 bolt goes for $1,200 and up. I scored a Mcloed RXT for $800
Used LSA supercharges go for $1,400 plus. Got mine for $1,000
Supercharger brick $1,100 for the one Im using. Used $650
Supercharger lid around a $1,000 and up but still hunting for this but im going a different direction then most for the lid
Old Apr 17, 2022 | 10:14 PM
  #216
NoEmissions84TA's Avatar
Re: LY6 carnage
Why is your crankshaft purple?
Old Apr 17, 2022 | 10:54 PM
  #217
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
That is the "Normal" appearance of the GM Stock (Heat/ Surface Treatment and Stress Relieving) Forged LSA Crankshaft.
Old Apr 18, 2022 | 05:09 PM
  #218
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Yep what vortec said. LS9 LS7 LSA and Im pretty sure the c6 grandsport ls3 with the dry sump got the forged crank as well.
Old Apr 18, 2022 | 06:17 PM
  #219
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LY6 carnage
My LS7 crank is dark like that too.
Old Apr 21, 2022 | 07:13 PM
  #220
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Well im past my budget and need to get this thing up and running on the cheap any help on the following parts would be helpful.
Single cooling fan 14"-16" needs to be strong enough to move air threw the new 3 core radiator.
Adjustable fuel regulator.
LS3 style injectors 850cc
Old Apr 21, 2022 | 08:51 PM
  #221
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: LY6 carnage
Boneyard time for the fan? Maybe a single fan from a 6th gen camaro? They have one giant fan. You should be able to nab everything else off the classifieds on ls1tech.
Old Apr 22, 2022 | 03:53 PM
  #222
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Yea that 6th gen fan might be the ticket hopefully find one used. Just a email update from BTR on a new product siemens/deca 92lb ls3 style $470 for the set!
Old Apr 30, 2022 | 05:15 PM
  #223
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Time to bolt on some heads
Old Apr 30, 2022 | 06:36 PM
  #224
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
I strongly recommend not using a stock Balancer (especially with a Supercharger).
A SFI Certified Balancer with dual Keyways would be substantially better.
Old Apr 30, 2022 | 08:09 PM
  #225
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Whats wrong with the stock LSA balancer?
Old Apr 30, 2022 | 09:58 PM
  #226
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
The Supercharger is VERY hard on the Harmonic Balancer.
The Outer-Section tends to rotate away from the Inner-Section...
Or completely come apart/ separate (lots of damage inbound).
Also sometimes the Harmonic Balancer will rotate on the Snout of the Crankshaft...
Even when One Keyway is used, failure still occurs.
Two Keyways 180-Degrees apart, is the way to go!
O! ...I almost forgot.
No Dowels or Pins!
Machine the Crankshaft Snout, and use high-quality Steel/ CrMo Keyways.
Old May 1, 2022 | 08:36 AM
  #227
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Im sure this balancer will out last the engine
Old May 4, 2022 | 07:31 PM
  #228
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Got the heads bolted down over the weekend. Next up will be small things cam an crank sensor then motor mounts. Then clutch assembly with trans following.
Hope the spal fan is on par with the hype had to go with a 14” cause I’m using the smaller c4 corvette radiator more to come on that later.
Old May 23, 2022 | 01:51 PM
  #229
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Ran into a big road block with RXT LSA clutch thats setting me back more money and two more weeks. I need a 8 bolt flywheel so that didn't leave me much of a choice so long story short the lsa clutch wont work with the older style T56. Monster is cutting me a 8 bolt flywheel now to go along with there twin disk kevlar kit.
Old May 24, 2022 | 12:19 AM
  #230
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LY6 carnage
Just for my learning, what was the issue encountered trying to mix those parts?
Old May 24, 2022 | 07:49 PM
  #231
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
With the Mcleod flywheel and clutch the overall thickness was way to much resulting in so much throwout bearing contact that the T56 wouldn't go into the bellhousing. And im not talking like 1/4 or 1/2" more like two inches lol
Old Jun 5, 2022 | 06:58 AM
  #232
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Back to making progress hope to get more done today and maybe a quick test fit of the blower.
Old Jun 6, 2022 | 05:19 PM
  #233
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
She looking thick!!
Old Jun 17, 2022 | 05:54 AM
  #234
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Ran into a issue when I went to test fit the G8 alt and PS. Big issue was with the PS bracket it just mounts the pump to low on the head which puts the pulley into the steering box. I got a cts-v bracket coming to see if this can work.
I ordered a racetronix fuel regulator and some fittings from them. Best prices
I have all of the lsa drive installed just need to put the belt on.
Old Jun 17, 2022 | 03:48 PM
  #235
vorteciroc's Avatar
Top Answer: 1
Re: LY6 carnage
Lookin' great!
Regardless of the Super-Charger dimensions...
That Intake-Manifold is really compact (which is awesome) especially as it houses the Inter-cooler.
Keep it up!
Old Jun 20, 2022 | 07:12 PM
  #236
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Very nice looking piece! Going to put another order in for a fuel pump. Still need a few more fittings and some 6an fuel line.
Old Jun 25, 2022 | 01:06 PM
  #237
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Everything just seems like it’s going slow with this build and the UMI autox event is coming up fast not looking good for this year.
Old Jun 25, 2022 | 01:14 PM
  #238
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LY6 carnage
That top on the supercharger looks gooooooood. That's not stock is it?
Gosh, that thing doesn't look hardly any bigger than the LS7 MSD intake! Is there maybe hope that would fit under Firebird hood?
Old Jun 25, 2022 | 02:57 PM
  #239
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Its one of crazy ideas so hopefully it works out lol. Basically what your looking at is a LS9 lid on top of a lsa blower. Advantages more clearance, better cooling do to twin bricks, price dsx lid $700. Disadvantage only thing is with the smaller lid volume it will hurt peak numbers some but could be made back up with a lid spacer if room is available.
Old Jun 25, 2022 | 03:01 PM
  #240
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Kong HD ls9 bricks got used for $500 new they go for $1,100 I think or 1,200. The dsx tuning lid also comes with a built in air splitter
Old Jun 25, 2022 | 03:06 PM
  #241
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
The ls9 lid option seemed like a no brainer cause if you have seen the Kong lid its the same lid for both blowers so I cant figure out why people are paying well over $1000 for the lsa lid.
Old Sep 15, 2022 | 09:11 PM
  #242
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Had first start lastnight.
I have a holley 2.5 bar map sensor but the holley efi software doesn't support it so didn't run to great with this. Going to order the GM lsa map and be done with.
Old Sep 15, 2022 | 10:22 PM
  #243
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LY6 carnage
Have you tried manually inputting the transfer function for custom sensor calibration?
Another option is the Bosch T-MAP sensors. MAP and air temp in one unit, pretty cool stuff. But you would have to input the transfer function for that too.
Old Sep 16, 2022 | 07:17 AM
  #244
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: LY6 carnage
Yea with the holley you can set custom sensor parameters... probably someone has it already and posted for the 2.5 bar sensor. I find it odd that they don't support there own sensor. I know with some of the newest updates they have added alot of additional preset sensors calibrations and injectors etc. Hook up a vacuum pump and test at vacuum with sensor hook up and record the voltage/bar, then add a compressor and test for max pressure and voltage/bar. Plot the numbers and make it linear and your good to go.
I think that lid will clear no problem. Doesn't look taller than the NNBS intake which clears my stock hood. I think the TB area is gona be a bit tight. I run the LS9 MAP just be aware the sensor nipple is bigger than the standard LS MAP's so on the stock plastic intakes you need to drill out the MAP hole... not sure on your blower though. It also doesn't use a thick rubber grommet, basically just an o-ring.
Old Sep 16, 2022 | 09:03 AM
  #245
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LY6 carnage
I found that too earlier this summer when I upsized from V4 to V6. They had more sensors pre-programmed and I was able to get rid of some of my custom transfer functions (GM oil pressure sensor in my case).
Old Sep 16, 2022 | 09:10 AM
  #246
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
With a stock hood it would clear with tons of room. I had to only trim a small section of the trackspec vent cause they sit so far under the hood.
The new map is only $40 I can deal with that
Anyone doing this with a cable t/b will need a 60" lokar.
Old Oct 6, 2022 | 11:12 AM
  #247
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LY6 carnage
Small update... First with the bad the new champion radiator was DOA had a small pin hole.
New map helped but was still dying right after startup unless I would crack the throttle. So with it shutting down in a second or two made it hard to find the issue. Lastnight i leaned in hit the key and then shot a squirt of carb cleaner into the t/b and it stayed running till it burned that up. So It ended up needing 10% more fuel in the idle area to fix it up. Had zero issue holding idle below 900.
Finally got it up to temp long enough to get water into the engine and I coolant exiting from both the front and back steam ports. Just had them both loosely ran to the over flow tank to make sure it all was working correctly.
I still need a heat exchanger and water pump but not much else.
Old Oct 6, 2022 | 11:25 AM
  #248
Car: 87 TA clone
Re: LY6 carnage
I did it with a lokar, not hard and did it with the stock 78mm and my 92mm Warr TB. I modified the pedal to accept the lokar end and SS washers on the firewall works perfectly.
Old Oct 6, 2022 | 11:27 AM
  #249
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
Re: LY6 carnage
Originally Posted by BOTTLEDZ28
That right there is how people end up in a drum in the ocean!!!
looks like he bought a $600 boat anchor
Old Oct 6, 2022 | 12:06 PM
  #250
Car: 1987 IROC-Z
Engine: 6.2L
Re: LY6 carnage
What a wild story. Back to a LS3? I saw 6.2L
