4th gen Radiator. What are you using for the upper hold down?
Old Aug 18, 2018 | 11:27 AM
BrianI's Avatar
Was test fitting what I was told was a 4th gen radiator into my 3rd gen yesterday. The factory 3rd gen radiator is wider so the rubber cushion in the hold down doesn't line up with the 4th gen radiator. What are you guys using for a hold down?
Old Aug 18, 2018 | 08:51 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 4th gen Radiator. What are you using for the upper hold down?
I used the stock upper, I had used it in another vehicle at one point so I had already trimmed the ends off to about the outer edge of where the rubber mounts are. I also had to trim the depth at the back so it would hold the fans onto the radiator, I wound up cutting off all the provisions for the 3rd gen fan. I think one rubber cushion lined up, but Ii don't remember what I did for the other side.
Old Aug 19, 2018 | 08:33 AM
BrianI's Avatar
I'm having the same issue. I was hoping to use the 4th gen radiator because of the way the fans and a/c condenser are secured to it. May just use a 3rd gen radiator and make some brackets to secure the fans
Old Aug 20, 2018 | 06:46 AM
nhra-trans-am's Avatar
I am using a 4th gen radiator and dual fans.
Here are some pics
Old Aug 20, 2018 | 06:52 AM
BrianI's Avatar
Did you make that hold down? Do you have some type of dampening material between it and the radiator?
Old Aug 21, 2018 | 08:11 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Originally Posted by nhra-trans-am
Why do you have the radiator leaned back like that? You're letting air get around it and it is lowering the cooling efficiency, you should really stand it up like the 3rd gen, or make some plates to block the sides so air can't get past
Old Aug 21, 2018 | 08:24 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Took a couple of pics of mine. I have the cushions on the bottom, but nothing on top. Again, I had trimmed this for another project, but you wouldn't need to cut off as much as I did
Attached Thumbnails 4th gen Radiator. What are you using for the upper hold down?-20180819_195226.jpg   4th gen Radiator. What are you using for the upper hold down?-20180819_195231.jpg
Old Sep 1, 2018 | 10:43 AM
Firebat's Avatar
Using a modified 4th gen radiator hold down piece. Took a dremel to trim it down. Then various sandpaper to smooth the edge.
Old Sep 21, 2023 | 08:07 PM
kestell123's Avatar
Car: 1991 camaro convertible
Engine: LS3
Transmission: 6l80
Axle/Gears: Ford 8.8 3.31 torsen t2r
I used a stock replacement radiator and stock single fan. LS3 with 6L80 additional trans cooler infront of AC condenser. No problems, even in southern heat [on trips] and AC cranked
82z28man
Dec 5, 2010 01:14 PM
RITTER
Feb 16, 2010 05:20 PM
GSRMmi31
Dec 7, 2009 04:16 PM
fast89ta
Fabrication
32
Aug 20, 2007 08:17 PM
snowman_az
Jul 30, 2006 12:00 PM
