Ohio?
Old Jun 24, 2013 | 03:13 PM
  #1851
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Ohio?
Originally Posted by Azrael91966669
so the 2500 stall didnt work so well for street driving lol
swapped back in a stock one
whats funny was ive been playing around with 700r4 govenors
the my cars stock gov when it was tbi shifts at 4400 1-2 4100 2-3
lol no wonder it was complete crap as tbi
i tried the 85 iroc gov from the blown trans shifts at 6400 1-2 6200 2-3 but in the 85 trans it was 5500 1-2 and 5300 2-3 odd
that will work well when i do the lt1 intake swap
i found a gov from a 92 full size van and it shifts at 5800 1-2 5500 2-3 ie perfect
the zz3 cam pulls hard up to 6000 but falls off after that even with tpi im expecting it to pull harder with the lt1 intake swap
once that happens ill need a tune like crazy lol
When are you coming to Norwalk again bud? Im going this weekend. Ive been at 13.0's quite a bit this year. Hoping to hit the 12s one of these days.
Old Jun 25, 2013 | 03:05 AM
  #1852
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: Ohio?
we didnt go friday because it said 3day race for 99
i plan on going this friday
Old Jun 25, 2013 | 03:14 PM
  #1853
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Ill be out there Friday after work. Probly not till around 6-7pm but I should be there.
Old Jun 25, 2013 | 03:48 PM
  #1854
project89's Avatar
Re: Ohio?
post up results friday night when ur done , ill be at work till 3am so 5 am ur time , this way i can check them out before i goto bed when i get home
lol im going to say 12.70 if ur leaving max boost the same as its been , possibly 12.55 if u can get the car to hook perfectly with the antilag
Old Jun 26, 2013 | 04:34 PM
  #1855
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Dave the anti lag is dot on at 4psi right now at 2600rpms in drive holding still on those crappy old slicks I have. Im going to make passes and turn up the rpms 100 at a time and see how high I can hold it. The boost will be back at the 11.5-12psi it was when I was making the 13.0 passes. I drove it the other day and beside the amazing burnouts it seems to come out of the antilag nicely and not bogg out or anything like that.
Ill post up the results though. I just want a dam 12 second pass...but if I can make somesort of 12.70-80 pass Ill literly go out and kiss my car...lol.
Old Jun 27, 2013 | 12:07 PM
  #1856
project89's Avatar
Re: Ohio?
good luck !!
Old Jun 30, 2013 | 07:58 PM
  #1857
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
I cant believe how much it rained this weekend. Some how dispite the flooding where my car was at in the pits..lol We managed to get the race in of Saturday. I finally made some 12 second passes.
Old Jun 30, 2013 | 08:14 PM
  #1858
Chevyman454bbc's Avatar
Car: 1989 Camaro RS Hard Top
Engine: 305 Bored .30 over
Axle/Gears: Stock
Re: Ohio?
Ashland here
Old Jun 30, 2013 | 08:57 PM
  #1859
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
Re: Ohio?
Congrats, the car has come a long way
Old Jul 1, 2013 | 07:44 PM
  #1860
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Thanks 355! It sure has came along ways.
Old Jul 3, 2013 | 11:20 PM
  #1861
Car: 1991 camaro RS
Re: Ohio?
my car seems to be showing the years of abuse lately ie trans failure and now i shattered pinon gear
i have a 9bolt to put in but apperently need the proper backing plates for my pbr setup
Attached Thumbnails Ohio?-100_8470.jpg   Ohio?-100_8463.jpg   Ohio?-100_8472.jpg
Old Jul 4, 2013 | 06:29 AM
  #1862
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Damm that's no good. Well at least you have another rear end to toss in.
Old Jul 4, 2013 | 11:05 AM
  #1863
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Ohio?
Better watch out for that Brominated Vegetable Oil BVO in the Dew. Have fun.
Old Jul 5, 2013 | 10:10 AM
  #1864
Car: 1991 camaro RS
Re: Ohio?
i am apperently not getting any luck one of the yoke bolts busted so now apperently have to drill an tap and i still have to do the brake swap so lets hope the rest of the bolts come off
Old Jul 5, 2013 | 12:52 PM
  #1865
project89's Avatar
Re: Ohio?
hey fast u ready for a race ? lmao
Old Jul 5, 2013 | 12:53 PM
  #1866
project89's Avatar
Re: Ohio?
dbl post
Old Jul 5, 2013 | 03:04 PM
  #1867
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
You know I am up for any race.
Old Jul 5, 2013 | 03:10 PM
  #1868
project89's Avatar
Re: Ohio?
haha im the same way even if i know im going to get my butt kicked, its still fun to try.
swapped out the cam in the iroc again and as u can see it built 6/7psi just free reving , havent had a chance to drive it yet since the battery took a dump on me, i have to jump the car to start it , and if i turn on the fans with the jumper cables disconected the engine shuts off , guess this massive heat wave we got killed the battery , cause it was fine 2 weeks ago
Old Jul 11, 2013 | 07:00 PM
  #1869
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Heading to the track all weekend as its suppose to be a beautiful weekend even after the tordados tore up my home town of Bellevue. Anyone that is coming to Norwalk let me know and ill save you a spot.
Old Jul 12, 2013 | 11:31 PM
  #1870
project89's Avatar
Re: Ohio?
how did ya do tonight?
Old Jul 13, 2013 | 12:21 AM
  #1871
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Re: Ohio?
Heh, not good. ICM took a dump on him we believe. Hopefully he can get it fixed for tomorrow.
Oddly enough, my first pass, I did my burnout, then blew the upper radiator hose off coming out of the burnout box. He helped push me out. 15 minutes later, his car was acting up coming out of the burnout box, and I helped push him out. Long night!
Finally got my car where it should be. 12.36 @ 111, with a 1.84 60'. Spun so bad I had to let off. This thing should be 12.0x pretty easily
Old Jul 13, 2013 | 01:29 AM
  #1872
project89's Avatar
Re: Ohio?
yeah i saw after he posted in the v6 section.
nice times btw
more then likley it will be icm or burnt plug wires , could also be his ignition box went bad , first thing i would do is bypass the msd and see what happens
Old Jul 13, 2013 | 10:57 PM
  #1873
project89's Avatar
Re: Ohio?
hope u had better luck today
Old Jul 14, 2013 | 09:56 AM
  #1874
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
It was the excitor ring on the dizzy. Somehow all three screws are missing. So I had to put it back on and the car ran good. It was pretty hot. I forgot to shift into 3rd on a pass and It was up to 6700rpms before I shifted...opps. My cam just suxs for high rpms so much that I don't need a dyno to tell, all I need is my butt dyno. Needless to say it ran a 13.30 on that pass, then in elimination I went a 13.11@92mph. I dumped it so hard the car swerved a bit..lol. Looking at the 1/8 mile times on the dumped pass it was online for a 12.90's pass so the car is back to where its suppose to be.
Old Jul 14, 2013 | 10:31 AM
  #1875
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
Re: Ohio?
went to the local carshow for the arthritis foundation in columbus.
Didnt win anything but I represented... thirdgens well i hope
my daughter thought so!
Old Jul 14, 2013 | 10:57 AM
  #1876
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Very nice!
Old Jul 14, 2013 | 11:46 AM
  #1877
project89's Avatar
Re: Ohio?
lol u need to start dialing in faster so u can stop nailing the breaks at the stripe
Old Jul 14, 2013 | 01:09 PM
  #1878
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Well if the car was more consistant...lol and I wouldn't forget to shift into 3rd
Old Jul 14, 2013 | 04:17 PM
  #1879
Engine: 5.0 TPI
Re: Ohio?
Very nice!
thanks! going to the Delaware Ohio show in 2 weeks. trying again
Old Jul 14, 2013 | 05:11 PM
  #1880
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: Ohio?
What's up guys? Been busy here with traveling and fixing up the GTA. I just replaced the center link, inner and outer tie rods, and ball joints. Also installed a Champion 3 core radiator and 24,000 GVW hayden plate style tranny cooler. I drove it down to Ellenton, fl. for 3 weeks and other than a blown heater core and stripped headlight motor, it did great and got up to 23 MPG on the way there. Good times were had, drinks were drank, women were bedded, and relationships were destroyed bwahahaha. Even got to live my dream of driving on Daytona Beach! Good times indeed.
Attached Thumbnails Ohio?-img_20130622_164840_068-1-.jpg   Ohio?-16251579_large.jpg   Ohio?-16251585_large.jpg
Old Jul 31, 2013 | 05:35 PM
  #1881
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: Ohio?
Toledo > Brand new Crate, ect, ect, ect. Life threw me a HUGE curve-ball and I have to sell this stuff....All listed below are brand new, in the box with all receipts showing my cost are the following:
Brand new G.M. Good wrench 350 Motor > still in the crate it was shipped in. Paid $1,500 Selling for $1,000 (my loss 500 bucks) actually with tax it was over 1,600 for the motor.....
Still in the box Holley 670 CFM Manual choke Street Avenger carb. Paid $355.00 Selling for $255 (My loss 100 Bucks)
Still in the box Edelbrock performer Intake with install kit. Paid $195.00 Selling for $100 (my loss 95 Bucks)
Still in the box Hooker shorty headers. Paid $165 Selling for $90.00 (My loss 75 Bucks)
If you buy the Motor I will throw in the brand new Water pump and flex-plate for free......
Toledo, Ohio >>>> PICK UP ONLY >>>> I priced everything with a HUGE loss to me just so I can move on<<< No Haggling Please this stuff is all brand new with receipts/box/Never Used.
Will part out > Local pick up only > Mike
I have had this in the "For Sale" section for a good 2 weeks so I hope the posting police will kindly let this one slide shifting it to this thread. Thanks to the Administrator and Moderators....
Thanks <Mike>
Old Aug 2, 2013 | 01:51 AM
  #1882
Car: 1991 camaro RS
Re: Ohio?
well i got my rs back up and running last week the flynbye backing plates worked great
so now its a 9bolt with 12inch pbrs
Old Aug 2, 2013 | 02:01 PM
  #1883
FattyMcFat's Avatar
Car: 1987 Iroc Z28
Engine: 383 ci
Transmission: Built 700r4 -Raptor
Axle/Gears: 3.90
Re: Ohio?
Wadsworth Ohio here.
Old Aug 2, 2013 | 03:39 PM
  #1884
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Sweet. Let me know when ya plan to go to norwalk.
Old Aug 8, 2013 | 08:45 PM
  #1885
Engine: 385
Re: Ohio?
Night Under Fire this weekend at Norwalk! Anyone other than me and Mark going to be there?
Old Aug 11, 2013 | 08:21 AM
  #1886
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
New best of a 12.88 this morning at the track. 1.76 60 ft time and man it felt strong at the line. I love the new line lock and tach with shift light. I can hold that puppy at the line all day @ 3k rpms now. Makes it so much easier. Ill post up a slip later after i get some sleep. Been up 27 hrs and counting at the moment. Late night of racing when you get your first round in at 7am...lol
Old Aug 19, 2013 | 06:15 PM
  #1887
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Couple pictures. I finally got the under hood area painted nicely. I added some stonger valve springs, retainers to match, and seals over the weekend so figured id clean up the valve covers, intakes and hood. And YES I finally dont need to use pvc pipe to hold the hood up!
Old Aug 19, 2013 | 06:57 PM
  #1888
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: Ohio?
And THIS is how you go camping.
Old Aug 21, 2013 | 02:11 PM
  #1889
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: Ohio?
Might have some much improved numbers to post up before the year is over. Snapped up a NOS wet plate system last night.
Old Aug 21, 2013 | 08:17 PM
  #1890
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: Ohio?
ooooooh
Old Aug 22, 2013 | 02:24 AM
  #1891
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: Ohio?
Got it all cleaned up. I'll get more pics tomorrow.
Attached Thumbnails Ohio?-img_20130821_162206_975-copy-1280x908-.jpg   Ohio?-img_20130821_162407_438-copy-1280x756-.jpg
Old Aug 25, 2013 | 01:56 PM
  #1892
bjmeuser's Avatar
Car: 1987 IROC-Z
Engine: 350 TPI. "5 7"
Re: Ohio?
I'm from OH!
Old Aug 27, 2013 | 03:07 PM
  #1893
XxadgexX's Avatar
Car: 91 Camaro
Re: Ohio?
I'm from Mantua, Ohio, 1Hr from Cleveland, 1991 RS.
Old Aug 27, 2013 | 04:02 PM
  #1894
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Re: Ohio?
Hello Ohio..I was thinking of going and making some videos out there for my thirdgen channel on youtube (klowny1969) .. might stop by for a show one day
Old Aug 27, 2013 | 04:53 PM
  #1895
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
cool. Im mauicamaro on youtube. Ive got some vids there. If I could round up some good thirdgen vids id like to start a comp. video sometime.
Old Aug 28, 2013 | 08:15 AM
  #1896
Engine: 5.0 TPI
Re: Ohio?
I have one out there.. 67micber
Old Aug 28, 2013 | 06:11 PM
  #1897
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Ohio?
I have one, but more of a what's done to the car type video... SimplisticBeing. I'm subscribed to you already fasteddi. Give me a couple weeks and I may have an '8yrs since last startup' video.
Old Sep 3, 2013 | 04:42 AM
  #1898
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: Ohio?
I'm budfreak on youtube.
Old Sep 3, 2013 | 04:44 AM
  #1899
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Re: Ohio?
Uuhh Ooooooooooohhhhhhhhh.
Old Sep 3, 2013 | 05:06 AM
  #1900
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Ohio?
Nice!
