Im getting there! bottle mounted
Old Apr 28, 2005 | 10:36 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Well, Im getting there. Bottle is mounted and feedline is routed. Go the selonoids mocked up but not tighten down.
Goona button everything down tomorrow and then the task of wiring all this crap up...THATS! not gonna be fun! Im not good with wiring.
Old Apr 28, 2005 | 10:37 PM
Old Apr 28, 2005 | 10:39 PM
Old Apr 29, 2005 | 07:52 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Why is it that when people show "how" they've mounted their bottle that they just show the bottle sitting there and not how it's mounted. I've got mine done, but everytime I did a search no one took pics of the brackets they used. Pictures of the brackets would be a lot more helpful.
Anyway, looks good. Oh, and the wiring couldn't get much more simple once you understand it.
Old Apr 29, 2005 | 08:31 AM
Yeah your right about mounted pictures, I did a search and didnt find anything either but from one of the pictures I seen I found that the guy mounted the brackets on the side of the car instead of resting on the bottom. I used the standard NX brackets that come with the kit and just held the bottle where I wanted it and made some marks, drill them out and bolted it on. I was only able to get 3 bolts on but the bottle is secure and doesnt move so im happy.
I should have thought about that and taken pictures of the mounted brakcets, when I take the bottle off to have it filled I'll take some pictures of the mounts just sitting there.
Old May 5, 2005 | 10:58 AM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
See my brackets?
Old May 5, 2005 | 11:00 AM
REALPOWER's Avatar
Transmission: Th350
Be careful with that nitrous...157 on the ticker of a stock 305 is not exactly a motor for nitrous. Hope its not your DD.
Old May 5, 2005 | 12:49 PM
yep its may DD. Its runs strong. I hope to not have any problems with it. what kind of problems would I have? Ive read of people sprayin motors with way more mileage than mine.
Old May 5, 2005 | 05:06 PM
REALPOWER's Avatar
Transmission: Th350
well, leaning it out for one...if will burn holes in your pistons, or break them apart. You probably want to run some bigger injectors...when you hit the nitrous, the computor is supposed to fatten it up. If your o2 sensor or some other efi problem exists, your motor will be toast. Make sure your fuel system is working 100% properly.
Old May 5, 2005 | 05:48 PM
I run a little rich anyways so maybe I'll be fine..only one way to find out.
But yeah, Im gonna be careful with it once I get it all hooked up and wired Im gonna be almost scared to try it..LOL
Old May 6, 2005 | 10:47 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Originally posted by REALPOWER
See my brackets?
Ya, but not what there bolted to, good job!
Old May 6, 2005 | 10:49 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
How in the world are bigger injectors going to help when he's spraying a wet kit? Please enlighten me.
Old May 6, 2005 | 12:31 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I have my NX bottle mounted in the same location but I only used the 1 "short" bracket and put it almost near the middle of the bottle. Bottle doesn't move.
Old May 6, 2005 | 07:37 PM
REALPOWER's Avatar
Transmission: Th350
I see 3 or 4 solenoids. If hes running a dry kit, bigger injectors are a must. If hes running a wet kit, which must be what he is, it is still not a bad idea, bigger injectors could give you a bit of a safety cushon in case of a leaning out. Please roll your eyes somewhere else.
Old May 6, 2005 | 07:52 PM
REALPOWER's Avatar
Transmission: Th350
Just finished my plumbing today What an expensive pain...350 in fittings and fuel line alone... NHRA mandates no more than 12" of rubber hose.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
