Stroked 305
Old Jul 3, 2001 | 02:06 AM
wildman923's Avatar
Stroked 305
Yes I am an idiot and I decided to stroke a 305. Was wondering if anyone would have an idea what my engine will run once I finish getting it in the car. 305 .030 over 400 crank. (Yes I know that I only have 15 thousanths of an inch bigger bore than stroke). I'm running a set of Eagle Sir Bushed 5.7 rods Keith Black 9.5:1 compression pistons. "041" heads from a 69 chevelle. and my cam is 224/230 @50 w/ .477 .480 lift. I'm still running the stock intake,carb, distributor and 2 1/4" exhaust. Anyone have an idea on my peak hp and tq?
BOB
Old Jul 3, 2001 | 04:05 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I remember reading an article a few years ago on a 334 stroker in Car Craft or Hotrod or one of the other rags. They put together one with a crank/rod/piston kit (I think from Coast). I don't remember for sure but I think they used Trickflow heads. Peak HP was around 350. I don't remember what the torque was but it was pretty good due to that long stroke.
Your "square" stoker motor resembles the bore stroke relationship of the 396 LT1 stokers.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Jul 3, 2001 | 08:27 AM
ATOMonkey's Avatar
Don't worry about your bore to stroke relationship. The new Northstar and 4.6 stang engines are both square and make plenty of power and good emissions. Just be carefull of detonation problems. I know that 305s were bad about that before stroking them out. Also make sure that your rod bolts don't hit you cam lobes.
Good Luck!
'87 Bird 350 .060 over 700R4 + Lots more
Old Jul 3, 2001 | 12:18 PM
wildman923's Avatar
Well I did have the car running 2 weeks ago until the carb decided to leak gas on the intake and then in about the time it took me to get the fire extinguisher my car no longer ran. When it was running though got into it a lil from a stop (3800 rpm into it) and the tail end started heading for the ditch. So I know one problem that I'm going to have (besides my car wanting to be a real Firebird) is traction. With the stock 3.23 spider's in the rear didn't think it'd kick out that quick. Anyone else have this problem?
BOB
'84 TA
334 SB
"041" heads
+ Dual snorkel and cowl air intake
More to be added once I harvest the money tree.
Old Jul 6, 2001 | 07:48 AM
Alan84TA's Avatar
I should know in a couple weeks. I'm just finishing up my '84 TA 335 stroker...
Old Jul 6, 2001 | 07:51 PM
wildman923's Avatar
305 strokers are the bomb
BOB
'84 TA
334 SB
"041" heads
Old Jul 12, 2001 | 11:20 AM
berlinetta85's Avatar
I have an LG4 305 nestled between my fenders. I'm looking to make this ride my daily cruiser. Thing is I'm looking for a little more perfomance, so my trip to work is a little more exciting. The car is stock as a rock accept for the 16X8 IROC rims I scored for $50. I'm new to the game and any advice would be greatly appreciated. Thanks!
Old Jul 12, 2001 | 04:30 PM
Brian K's Avatar
RHS sells a 334 kit for the 305.. It rocks... It really adds some HP
Old Jul 13, 2001 | 02:53 PM
firebird305's Avatar
I've heard that stroker 305's perform really well,I wouldn't mind building one in the future.
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
Old Jul 14, 2001 | 01:01 PM
ImportsRsloths's Avatar
305 Strokers ARE THE SHI*!!! Who makes a good quality cheaper 305 kit??? (i need the web address)
Old Jul 15, 2001 | 03:39 AM
black84ta's Avatar
what does the kit cost? i'm thinking about building one for my 83 z28.
Old Jul 15, 2001 | 06:09 AM
wildman923's Avatar
You can pickup a kit from Powerhouse for around 600. I didn't do that when I built mine, It's cheapor to do it that way but I wanted to make sure all the parts I used where going to last. I bought a regular ole 400 Crank and had it ground down. Decided to go with a set of 5.7" bushed Eagle Sir Rods (Love full floating pistons). Then I went for a set of Keith Black pistons PN# KB186. Also got a B&M 400 flywheel. So far I have about 2,000 in my engine alone. Yes I know I could have built a 350 cheaper but it's fun telling people I have a SB 334. They can never figure it out.
BOB
'84 TA
334 SB
"041" heads
Old Jul 19, 2001 | 01:04 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I work with a guy at night(moonlighting)and we are buillding a powerhouse 335 for a guy he knows. we started filing the top rings tonight, keith black pistons. the stroker kit is ok, KP pistons, looks like stock recondtioned rods, and the crank. he is putting a SLP cam in it, which one i cant remember right now. touqer S/R heads, edelbrock headers and cat back, roller rockers, edelbrock lower, different runners, dont remember which upper, accel this, flowmaster that. the thing should run really freakin good. the only thing we are wondering about is, what fuel pressure to run? any ideas?
Wide Open Till You See God...Then Brake
Old Jul 19, 2001 | 11:26 AM
Brian K's Avatar
RHS Automotive claims 280HP - 320HP with their kit on carbed car....
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
