How much power will 2 bolt take?
Old Mar 2, 2007 | 01:18 PM
bbbates14's Avatar
i've got a 390 hp roller 2 bolt and i'm wondering if i can get away with 50 or 75 squirt.Anybody here got a hi horse 2 bolt that is handling a lot of power? I would really like to hear about your setups or E.Ts.On the bottle or not.
Old Mar 2, 2007 | 03:43 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
probably
Old Mar 3, 2007 | 08:48 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
9.75 @ 142MPH
700RWHP
http://www.turbomustangs.com/smf/ind...?topic=61219.0
Old Mar 4, 2007 | 04:30 PM
GTO's Avatar
GTO
Some will argue the 2 bolt is stronger then a factory 4 bolt.
Old Mar 4, 2007 | 05:10 PM
bbbates14's Avatar
wow turbo thats a ton more than i was expecting.
...yeah i've heard some people say they are more forgiving than 4 bolts also
Old Mar 4, 2007 | 10:33 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Wow...
I was told that the block becomes "iffy" at around 600 hp... Obviously, that depends on the individual block itself, & if you're building for big numbers, you'd be well-advised to have someone sonic-check the block...
Also, I've heard that turbochargers are pretty easy on parts (compared to blower/N2O), does anyone have any feedback on that?
But... wow... Maybe that 4340 crank I was looking at is a worthwhile investment...
Old Mar 4, 2007 | 10:34 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I bet his main bearing caps are doing a dance.
On a 350 the four bolts are stronger, It's the 400 block that the two bolt is supposed to be stronger.
Old Mar 4, 2007 | 11:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Forced induction in general is easier on BOTTOM end parts than high RPM. High RPM power is hard on the rotating assembly, since it's the change in direction of movement at high RPM that's the hardest. The high cylinder pressure of forced induction is harder on head gaskets the top of the piston more than anything.
Old Mar 5, 2007 | 08:01 AM
327???'s Avatar
the only way you can get a splayed 4 bolt is if you start with a 2 bolt, i'd say in the end it's better to convert a 2 bolt into a splayed 4bolt, then to use a factory 4 bolt.
Old Mar 6, 2007 | 03:24 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Well in any case I think your motor will be able to handle 90hp shot.
Old Mar 6, 2007 | 05:47 PM
bbbates14's Avatar
thats great.thanks for your input guys.now i just hope the tranny will handle it too.Gotta love finding and fixing those weaker links on your way to your dream car eh?
Old Mar 7, 2007 | 10:20 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Originally Posted by 89JYturbo
That guy can tune an engine very well. The 2-bolts seem to take the abuse if tuned properly. An engine will live longer if the spark and fuel are correct for it. 89JYturbo's car goes very well also. They took their time getting it right. So if you are careful then you can get good power out of a 2-bolt without it coming apart.
Old Mar 15, 2007 | 06:22 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
You are 100% correct.
I have a 2bolt block and stock crank. I estimate 600 rwhp. That comes out to close to 700 crank horsepower. You'll be fine.
Last edited by TurboedTPI; Mar 15, 2007 at 06:24 PM. Reason: Automerged Doublepost
Old Mar 15, 2007 | 06:44 PM
DMitchell05's Avatar
lol yep, it'll be alright No worries.
Old Mar 15, 2007 | 07:17 PM
EndlessSummer85's Avatar
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
As long as it was built right. Rods and mains torqued to the right specs i'd throw a 100-200 shot its way. I wouldn't worry about it. Just get the AF ratio dialed in and you'll be straight.
evilstuie
Apr 14, 2016 08:52 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
