TURBO MY 3.1
TURBO MY 3.1
HI ,IM TURBOING MY 1991 FIREBIRD V6 3.1 SHE ISNT FAST BY A LONG SHOT NUT STILL RUNS DAM GREAT ANWAY I WANTED TO AFTER I TURBO MY 3.1 AND MAYBE FIND SOME HEADERS FOR IT IT ALREAY HAS DUAL MUFFLERS SHE'S NOT BAD I WAS JUST WONDERING HOW MANY HORSES CAN I EXPECT TO HAVE WITH THESE MOD'S
1.TURBO
2.MAYBE HEADERS
3.PERFORMACE CHIP
4.IF POSSIBLY I DUNNO RAM AIR HOOK-UP/COLD AIR
HOW MUCH HORSE POWER COULD I WOUND UP WITH THAX
I READ A ARTICLE ABOUT PEPLE ABOUT A GUY DOING IT STEP BY STEP THANKS A MILL!!!!!!!!!!!!!!!!!!
1.TURBO
2.MAYBE HEADERS
3.PERFORMACE CHIP
Re: TURBO MY 3.1
dude lay off the CAPS,
if u read the links i gave u, all of ur ?'s will be answered,
#2 u cannot use an aftermarket off the shelf chip with a turbo setup,it will destroy the motor the first time u step on it and go into boost.
u really cant do ram air with a turbo,u can do somewhat of a cia depending on were and how u mount it.
before u do anything else i highly suggest u reread the links i gave u,and also do alot of research on how turbo systems work,
Transmission: 4L80E/4L80E
Since this has nothing to do with engine swaps, moving to Power Adder.
CAR PICS
I was confused on whar cars you own as posted in other post. I to have a 91' firebird I just bought. What all have you done with it. Mine is a 305 TBI and am in the middle of restoring it now.
Would like to see some pics of the motors and of the car for body comparisons. It would seem the previous owner was in the middle of modifying it when I bought it.
:: CHRIS
:: CHRIS
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Re: TURBO MY 3.1
i need help any suggestions people tell me to screw that and throw a 350 or a big block and get more power but i dont have great wrench skills or know nothing about doing a swap i could use some help and even put some $$$ in someone pocket in here in pa near airport
Re: TURBO MY 3.1
well if you dont have good wrench skills i wouldnt even bother with a turbo, thats alot of customizing. i helped out putting a new turbo on a 87 starion and granted its not a fbody but damn its alot of work. if you want the best bang for your buck and only want to spend a couple hundred bucks and swap to a v8, get nitrous.
Re: TURBO MY 3.1
http://s158.photobucket.com/albums/t...ird/?start=all
Here's some of what you would have to do...
Re: TURBO MY 3.1
ok i never did and engine swap so i'm totally in the dark here anyone can help me 350tpi or carb 350 which is better?hellllllllllllllllllllllllllllllllllllllllllllllllllllllppppppppppppppppppppppppppp
Re: TURBO MY 3.1
a carb is more basic and probally gonna be a little cheaper, where as a FI engine will be more electrical and more money, but ultimatley could mean more power if done correctly.
you could go to a junk yard and get a cheap 350 block for a couple hundred dollars and then totally rebuild it, but personally i think just getting a crate 350 would be best.
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: TURBO MY 3.1
Pick up a manual and start to read. your going to be doing allot of it from the looks of things.
Re: TURBO MY 3.1
I'm in the process of turboing my v6 right now and let me tell you, if you don't have much experience with cars it will be much easier to swap in a v8. If you're ambitious and have at have a friend who knows about cars and can help you then go for it, but a v8 swap is much easier.
Elephantismo
Feb 13, 2019 12:51 AM
