turbo install help
Old Sep 3, 2008 | 12:57 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
turbo install help
hey guys im getting a turbo for free, and was wondering what all i need and have to get to put it in. and what kind if tuning do i need. thanks guys
Old Sep 3, 2008 | 07:12 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: turbo install help
What are the specs of the turbo?
Old Sep 3, 2008 | 10:47 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yeah, what he said.
Just because it is free doesn't mean it is worth installing. It has to be within a certain size range to work properly. After you figure out if it is usable then start looking at what you need for other parts.
Old Sep 3, 2008 | 12:04 PM
Engine: 355
Originally Posted by junkcltr
Yeah, what he said.
what size do i need? im new to turbos and would like to learn more bout em
Old Sep 3, 2008 | 01:23 PM
junkcltr's Avatar
Engine: 3xx ci tubo
It depends. What kind of torque/HP are you looking for? What do you like better High RPM / late spool, Low RPM / quick spool, or something in the middle?
What size engine and what are the mods from the stock setup?
What did the "free" turbo come off of?
Old Sep 4, 2008 | 01:10 AM
Engine: 355
im just looking for maybe up to 400hp. i have a sbc 350, edelbrock performer intake, carb, hooker headers, vac advance dist,, accel coil and igniton module, and force exhaust mufflers w true dual pipes
Old Sep 4, 2008 | 10:17 AM
junkcltr's Avatar
Engine: 3xx ci tubo
A single T4 or a pair of T3s would work.
Old Sep 4, 2008 | 10:32 AM
2000chevys10's Avatar
alot goes into a turbo build if you want a good setup, you are going to have to either buy the headers and cross overpipe or make them and then comes the cold side of the setup (intercooler to intake), oil lines, ect. Be patient if you want to spend $4500-$6000 on a kit i did a setup on my 1995 ford mustang gt and spent $2200.00 but i made the kit. The car when we got done made 835 hp and ran a 9.20 in the quarter. Number one thing in a project like that is research and planning because if you dont you will spend more money than you should have in the long run
Old Sep 4, 2008 | 12:43 PM
Engine: 355
the turbo came off an older rx7 so dunno if itll work or not
Old Sep 4, 2008 | 01:57 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Here are good places to start:
new to turbos?
noob faq list
jy turbo list
Old Sep 4, 2008 | 02:09 PM
project89's Avatar
an older rx7 stock turbo will be way to small
Old Sep 5, 2008 | 12:40 AM
Engine: 355
thanks guys
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
fasteddi
Sep 2, 2015 10:29 AM
crazynights
Aug 21, 2015 06:53 AM
