Head Gaskets for blower
Old Jan 20, 2014 | 07:05 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am adding a D1SC to my car and will be running about 10 to 12 lbs of boost. What would be a good head gasket for my set up?
Old Jan 20, 2014 | 08:19 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Re: Head Gaskets for blower
Fel Pro 1003
Old Jan 21, 2014 | 07:44 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
I would do a MLS headgasket.......that's what im running on my turbo charged 355. ive had the 1003 go bad before but that's just my 2 cents.
Old Jan 21, 2014 | 07:51 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I've ran stock gaskets to 16 lbs (never detonated) and my friend RE-used a set of Felpro 1003'a and ran 24 psi with them! I am running Cometic MLS on my new engine and have detonated bad at 18 psi with no issues (car leaned out due to fueling problems).
Old Jan 22, 2014 | 06:46 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Would these two be good choices for a blown motor?
http://www.summitracing.com/parts/sc...make/chevrolet
http://www.summitracing.com/parts/cg...make/chevrolet
Old Jan 22, 2014 | 09:19 AM
The MLS is a better choice. With any copper gaskets, you have to install o-rings in your block.
Old Jan 22, 2014 | 10:02 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I tried those expensive cometic MLS gaskets a while back. The guy on the phone at cometic kind of freaked me out with the machining requirements required for the gasket to not leak coolant. He recommended I spray both sides with gasket sealer.
I threw them in the trash and used a Felpro #1014.
The felpro gaskets have the wire ring that crushes sealing the cylinder. They have rubber raised traces around the water ports. You torque the heads once.
I can tolerate a blown wire ring. I can't tolerate coolant getting into my oil and taking out a $2500 rotating assembly.
-- Joe
Old Jan 22, 2014 | 10:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I never reuse mls gaskets even tho they say you can. On a fresh block with fresh heads the surfaces are great for mls. No issues in my motors. I ran felpro mls and cometic. Cometic currently on my setup thats been disassembled and just scrubbed clean, and no issues. No leaks. Not that i expected any. No spray on coatings either
For stockish bottom end deal that may not have smoothest finish some other type gasket may be better, or atleast a thicker mls
Old Jan 22, 2014 | 02:38 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Running Cometic MLS gaskets here. 2.5 years and not a problem yet. Not like I expect any either, like Orr said. I'm running ARP head studs and with the fine thread pitch on the studs and following ARP's spec of torquing the nuts to 80 ft lbs, there is WAY more clamping force on the heads than using the stock head bolts at 60 ft lbs or whatever the spec is.
Are you running studs?
Old Jan 22, 2014 | 02:43 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks for the replies. I am probably buying the head studs today for the motor.
Old Jan 22, 2014 | 03:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Lol i only run 70 ftlbs studs with arp lube. No pushing water yet at 24 psi boost. Hope 30 holds
Old Jan 23, 2014 | 06:23 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't know what your deck finish is like. A lot of machine shops after decking the block will leave a finish that will almost catch a nail. It's not like they go over the deck with an end mill, it's a giant rotating cutting wheel.
http://www.performanceblocks.com/Eng..._Surfacing.jpg
If the finish isn't smooth enough, I know cometic gaskets will fail. I've never had an issue with the felpro gaskets.
The stud vs bolt thing on a SBC doesn't really matter. We've got 17 head bolts in almost a perfect layout. Head studs really help on stuff like powerstroke 6.0's that don't have enough head bolts by design.
-- Joe
-- Joe
Old Jan 23, 2014 | 12:17 PM
im running a set of mls that i cleaned up and sprayed with copper spray with no isues and also running regular sbc headbolts from gm as well on 15 psi of boost.
Old Jan 23, 2014 | 12:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Mine isnt mirror polished smooth but doesnt catch a nail. This is my second attempt with mls gaskets by cometic and again no issues noted. I even used the felpro blue mls that get a reputation for not sealing well and it also never had an issue. I guess my luck is better than others?
Old Jan 23, 2014 | 03:14 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
MLS all the way. This is the Power Adder forum right? Then why not use studs anything less, your playing with fire!
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
