60 seconds between searches??
The reason why there is a limit, is because searching puts a load on the server, especially multiple searches, and even more so on forums this large and active. I do not believe lowering it down to 15 seconds would get approval from the server administrators. I cannot think of any large forum I frequent that doesn't have atleast a 30 second wait period. It might be lowered, but I do not believe down to 15 seconds.
Car: 87 Camaro IROC
ya its kinda a pissoff, cuz usually i do a search and im wrong, and after 5 mins of waiting to ask 4 different search peramaters, i give up and post a new thread, and info is repeated. is it really worth it in the long run, cuz now ive taken up more space by posting an already posted thread, and other ppl reply, suddenly its out of control. perhaps saving more room would be able to allow ppl to delete thier threads or posts if they posted incorrectly or accidently in the wrong forum.
PS: that was hypothetical, i dont do that but im sure everybody else that says "ive searched but nothing comes up" has done it.
perhaps its time to look at the big picture and make some changes to free up bandwidth. or are you guys stuck in the past and are gonna be stubborn about it?
To my knowledge, we don't need more "room" (hard disk space for database nor bandwidth). There is not a good enough reason to allow members to delete their own post, and there hasn't been for the past several years that this policy has been around. If you post incorrectly, you can inform a moderator or administrator and it will be taken care of. This has been addressed before.
I can only suggest that if you make so many mistakes with the search engine, that you take a bit more time and care when typing in your search criteria. I admit that the 60 second search time out could use lowering, but to suggest that we are stuck in the past, or don't have the bandwidth, is not correct.
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Also keep in mind JT that many people who post have no idea as to the costs of bandwidth, server load and such, I'd let such comments just blow by. Either that, or they work for larger companies and have no idea of the limited resources of an organization such as this, as it is no issue to them.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Using the search feature uses a lot of bandwith. If the search time was lowered to something very low like 15 seconds, this would put a lot more stress on the server. It could very well cause TGO to be slow. Then people would be complaining about how slow TGO is.
It does put more of a load on the server via mysql, which a board this size, already is "busy" with other board functions.
I couldn't recall the previous search restriction time limit, which was 45 seconds as stated. As IrocThe5.7 stated, there has to be a balance maintained, otherwise search jobs could start to slow down the entire forums, which would lead to more logged complaints because it would impact a larger percentage of people who simply browse the forums or post. TGO is a big board, with quite a bit of activity, something that may not be so understandable.
Are you sure about that? According to Jason, this should not be the case:
https://www.thirdgen.org/server-maintenance-09-28-2006
I admit I haven't looked into it at the moment, but will to see if this is a valid issue.
There is still a 60 second wait between searches (this does NOT apply if your first search returns no results)...
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Sure, many forums have search wait time, but I would think that TGO, being a site that prides itself on the ammount of well maintained archived information it has, would have a flawless, fluid search function with which to take full advantage of this wealth of information. Searching should be the primary focus of this site, it's how we thirdgen owners access our information. Something has to change.
Thanks for the information. The issue will be reviewed and checked to see if we possibly can lower some of the restrictions. However, please understand that all restrictions cannot be removed and that there has to be a time limit to ensure that the searches don't impact the majority of users/viewers who browse and post on the forums.
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
wigmobile
Feb 26, 2025 02:56 PM
Linson
Sep 21, 2015 01:08 PM
bubbaz28
Sep 18, 2015 02:09 PM
Bob88GTA
Sep 10, 2015 09:07 PM
