Southern California Area Southern California Members.
355 Engine w/ ported 113 Corvette heads CA (SOLD)
Old Nov 21, 2019 | 12:45 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Low mileage 355 cu.in. forged pistons, ZZ4 rods, LT4 hot cam, roller tip rockers and dual springs.
$1200
Old Nov 21, 2019 | 01:17 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: 355 Engine w/ ported 113 Corvette heads CA
$1200
This seems like a great deal Don! Practically what I’m trying to build myself. Wish I was in California!
Old Dec 11, 2019 | 12:20 PM
Steve's Avatar
Car: 91 Z28
Is this still for sale? How many miles and what would be needed to replace my current stock 91 350 with this one?
Old Dec 11, 2019 | 01:33 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Wow! If this was closer id be all over it, great deal someone will get
Old Dec 12, 2019 | 08:47 AM
Dyno Don's Avatar
Yes it is Just drop it in.
About 3k
Old Dec 12, 2019 | 11:40 AM
Steve's Avatar
Car: 91 Z28
What kind of power can I expect from this build? Also do i need to get new manifolds/headers to accommodate the EGR?
Old Dec 12, 2019 | 11:43 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
You'd definitely need to do something to accommodate the EGR as the vette setup differs as you noted, being in CA.
LT4 hotcam is a decent mild cam.
Old Dec 12, 2019 | 04:47 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Don, what's the compression ratio? If Steve does not take the engine, I am interested. Yes, the L98 I bought from you is coming along nicely. I still have room for more engines!
Old Dec 12, 2019 | 06:48 PM
Dyno Don's Avatar
It is 10.5
The EGR tube can be added to the right side header, but you would need an aftermarket intake or one from a Corvette.
Old Dec 12, 2019 | 06:59 PM
Engine: 350 TPI L98
Transmission: WC T5
Thanks. Will the L98-LB9 exhaust manifolds and Y-pipe fit up or are the exhaust ports located differently?
Old Dec 12, 2019 | 08:40 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Used both L98 cast iron and the 113's, they both bolt up to stock iron exhaust from the L98..
Old Dec 14, 2019 | 11:45 AM
Dyno Don's Avatar
Maybe 315/320 to the wheels
Just add the Corvette tube to the header
Old Dec 14, 2019 | 04:18 PM
Engine: 350 TPI L98
Transmission: WC T5
PM Sent
Old Dec 19, 2019 | 10:54 AM
Dyno Don's Avatar
Back up for sale
Old Dec 19, 2019 | 03:28 PM
Steve's Avatar
Car: 91 Z28
PM Sent
Old Jan 23, 2020 | 08:01 AM
Matthew1821's Avatar
Car: 1992 Camaro Z28 25th Anniversary
still for sale?
Old Jan 23, 2020 | 09:21 AM
Dyno Don's Avatar
Still spoken for already
Old Jan 23, 2020 | 11:35 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
This is a steal!!! Lot of engine for the $.
Old Jan 30, 2020 | 10:33 PM
Shinobi'sZ's Avatar
If the deal falls through please let me know. I can drive down and pick it up...maybe get a pair of your headers if you have a set still too.
Old Feb 18, 2020 | 10:50 PM
jclopezz's Avatar
Car: 1991 Z28
Transmission: WCT5
Axle/Gears: Positive 4.10
if these guys lag, I could pick it up any weekend at your convenience. same with the headers and y pipe
Old Mar 17, 2020 | 02:21 PM
Axle/Gears: 4.11
Jeez, just buy it already someone this is a strong engine for the $.
The egr thing is cake to get around.
Old Mar 18, 2020 | 10:51 PM
Steve's Avatar
Car: 91 Z28
Hi Don. Sent PM
Old Mar 30, 2020 | 11:58 AM
Dyno Don's Avatar
Ready to go
Old Mar 30, 2020 | 12:59 PM
Shinobi'sZ's Avatar
Don I PM'd and called you. If available I can pick up this weekend.
Earl 87gta
Feb 22, 2010 11:06 AM
SheldonZ28
Dec 28, 2006 05:42 PM
Riker
Jul 31, 2005 11:06 PM
iroc_cragg
Oct 5, 2002 11:01 PM
