can front control arm bushings be pressed out with rented tools?
Old May 7, 2002 | 09:07 PM
breathment's Avatar
I need to do my front control arm bushings.. Can i just goto autozone and rent a tool to press them out and press them in? Or do i have to go and spend $100 or so to have a shop do it?
Old May 7, 2002 | 09:41 PM
urbman's Avatar
Depends...
Different shops have different tools...
Often they will have a ball joint press that you can use for this purpose.
If you have the a arms out it is not too soon to
start soaking the ends in a penetrating oil.
take your new bushing with you when you go to the "zone"
or somesuch. Ask to see the tool.
The reach of the ASSEMBLED tool needs to be a twice
the length of the longest bushing.
Hmmm...
for 100.00 bucks you could buy a press from Harbor Freight
Old May 7, 2002 | 10:32 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The AZ I went to didn't have a bushing tool. I had mine done by a shop and it ran me $100. WELL worth it in my opinion. Dropped them off, picked them up 4 hrs later. That's only $25/hr labor and I didn't get pissed off.
My .02
Old May 7, 2002 | 10:38 PM
TopForm's Avatar
IMO, if you can get/rent the proper tool, it would be worth it to attempt it yourself and save the bucks for something else. It's really not that hard of a job if you've got your control arms out already.
Brian
Old May 8, 2002 | 07:50 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I tried to press mine out but couldn't get the a-frame in the press at the right angle. Gave up and dropped them off at a local garage. They replaced the bushings and ball joints for $15 an arm, and didn't even bend anything! Best $30 I ever spent.
Old May 8, 2002 | 10:13 PM
breathment's Avatar
should i try replacing engine mounts while a-arms are off?
Old May 9, 2002 | 02:05 PM
kevinc's Avatar
Car: 1982 Z28
That's a great time to do it, doesn't get any easier to access the nuts inside the crossmember than with the A-arms off.
Old May 9, 2002 | 03:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Really! Hm. Gotta see if I can find poly mounts for my v6 motor. After 232,000 miles, they've gotta be tired! Hopefully someone's started making them in the past few months...
Old May 9, 2002 | 05:44 PM
89blackbird's Avatar
I did mine with a ball joint press I bought on e-bay for 45.00 . Works good but helps to have an extra set of hands to hold it in place till you get everything lined up. I would not try this if you don't have an impact gun. Good luck.
Old May 9, 2002 | 10:16 PM
Jza's Avatar
Jza
Are you serious? There's a shop up here that does both arms control-arm bushings for $20 if you bring in the arms. I believe they use an arbor press with a spacer in between the legs of the control arm.
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
