why do the 88/89 and up 3rd gens feel tighter?
Old Nov 19, 2002 | 11:38 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
whats different about the suspention on the later year 3rd gens to make them feel more stable and ridged?
Old Nov 20, 2002 | 09:25 AM
AFreaknGoodTme's Avatar
as apposed to an 82 or 83 I would have to say metal fatigue and worn out bushings. They have seen six more years more road use.
Old Nov 20, 2002 | 11:56 AM
MdFormula350's Avatar
yeah i agree, depending on the mileage of the car..
stuff wears out over time..
Old Nov 20, 2002 | 01:54 PM
Momar's Avatar
They also started using bigger swaybars and possibly better springs the newer the car was. It also depends on what model each was. I read an old article on someones sight from car craft or something like that. They were testing out a mid 80s WS6 transam and they stated that it had a much better feel than the iroc they tested earlier. I think that this may have been due to the fact that the ws6 began using bigger swaybars earlier than the camaro. With new/upgraded parts you could make any f-body handle as good as another since all of the parts are interchangeable.
Ben
Old Nov 20, 2002 | 03:01 PM
Slow91bird's Avatar
I "heard" (through the internet ) that GM stiffened the chassis a bit for the final years. Not sure what years, or if this is even true, but I agree that mileage is also probably a factor.
Old Nov 20, 2002 | 04:13 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: why do the 88/89 and up 3rd gens feel tighter?
Better springs and sway bars, no to mention GM started using better adhesives in the body so they don't "loosen up" as much as the earlier cars.
Our cars have a bad rep for rattling and squeaking as they age. The earlier models are the worst.
Old Nov 20, 2002 | 05:49 PM
86IROCTHD's Avatar
Car: 88 Trans Am
thanks
thats guys great INFO
Old Nov 20, 2002 | 06:35 PM
Momar's Avatar
Re: thanks
dont your worry welcome
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
