bleed screw
Old Jul 12, 2004 | 06:19 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
bleed screw
i need help, today i bled my brakes, or tried to...i was only able to do the rear brakes, when i went to the front the screw was so damn tight it was being a pain to get loose , and tips? , i used a socket for the rear drums<so easy with a socket wrench...i went to autozone and the *******s didnt even know what size wrench i should use to loosen it, what size should i get, i was using a 10mm socket but the 10mm wrench didnt work,
Old Jul 12, 2004 | 07:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I use a box end 10MM wrench on mine.
Old Jul 12, 2004 | 08:14 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Me too. 6-point. Don't round the hex off the bleeder that way.
Old Jul 12, 2004 | 08:15 PM
Spdfrk1990's Avatar
Hmm thats what happens when you dont have any caps. Where they covered up.
Old Jul 12, 2004 | 10:27 PM
Car: 1990 firebird
Engine: 3.1 v6
nope they were all off , suprised i got to the back ones easily, i had purchased a 10 mm wrench but it didnt fit?, maybe i picked up the wrong one, damn autozone
Old Jul 13, 2004 | 03:10 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
If you're bleeding the brakes just pull the caliper compeltely off and put it in a vice or something to hold it down while you yank away. Easier angle.
Old Jul 13, 2004 | 07:11 PM
Car: 1990 firebird
Engine: 3.1 v6
hm i was thinking about that, will a 3/8 wrench fit the bleed screw, i accidently picked up the 3/8 bleed wrench instead of the 10mm, i heard the 10mm is a hair wider?
Old Jul 13, 2004 | 07:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You are correct, the 10MM is in between the 3/8" and the 13/32" wrench size.
Old Jul 13, 2004 | 07:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/techbb2/sho...hreadid=250171 Take the advice I gave this fellow with teh same problem.... otherwise you'll end up about the same as he did I expect
Old Jul 14, 2004 | 03:25 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
My bleeder snapped off (see my thread) and I even used a lot of PB Blaster prior to attempting to turn it. Some people just get no luck.
Old Jul 14, 2004 | 03:40 PM
Car: 1990 firebird
Engine: 3.1 v6
i got it to open bro, yeh i peeped your thread, that sucks, i was thinking about that when i was gently trying to pry the old screws open, good thing they didnt snap on me ,, now i just have ****ter breaks, im going to have to bench bleed the mc and do the whole process over AGAIN, another 5 bucks for fluid and another 5 for the kit
btw i used a bleeder wrench, 10 mm, dont do what i did and pick up the 3/8 by accident, so identical yet so different
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
