Binding while turning, please help
Old Mar 19, 2005 | 09:04 PM
Cooter77's Avatar
Car: 89 IROC-Z / 11 2500 Sierra
Engine: 5.7 & Duramax
I just installed Ebiach Sportline springs, bilstien struts, ES bushings(LCA, Sway), LB joints, Outer Ties, Inner Ties, Center link and Idler.
Did all ES bushings in Rear and fab'd a new pan bar.
After my FEA when I turn wheel at slow speeds like i'm turning right from stop sign. If I turn the wheels half way it seems to bind up and jump. Feels like 4x4 with front locked in and trying to turn sharp.
Is this normal....???
Has anyone had this problem...???
I replaced the Stearing box couple years ago.
Old Mar 20, 2005 | 03:17 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine does that when the tires are cold, but my problem is due to my tires, Nitto 555RII road race tires. When the tires are warmed up it doesn't hop at all when turning from a stop.
Old Mar 20, 2005 | 10:25 PM
Cooter77's Avatar
I think its an alignment problem... I'm gonna call em up tomarrow and make em do it again.
Old Mar 23, 2005 | 12:06 AM
Cooter77's Avatar
The tires are hitting the inner fender when turning.
Becuse of the lowering kit. I could not see this while the wheels are dangling in the air.
I guess the only solution would be to purchase skinner tires....
245 to 235 if I can find em
Bill
Old Mar 23, 2005 | 01:14 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Something else isn't right. You should be able to run 245's. There are tons of people (including me) that run 245s and larger with sportlines...
Is your steering gear all correct? Lengths and stuff?
Old Mar 23, 2005 | 01:31 AM
Zepher's Avatar
I ran 245's with my Sportlines and they were fine.
With the 275's I get some rubbing when turning the wheel to the extremes.
Old Mar 23, 2005 | 02:08 AM
83 Crossfire TA's Avatar
it depends on what stops are in his steering box. My '83 TA and my '87 Formula have the same box ratio, but the '83 has 15" wheel stops and anything wider then the stock 215 65 15's would rub at full lock which is not the case at all on the formula. Running small spacers on the font fixed it but it really isn't a problem anyway.
Old Mar 23, 2005 | 02:14 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I was under the impression that stock, 89 iroc's got the 16" wheels? Just assumed he had the 16" stops rather than the earlier ones...
Old Mar 23, 2005 | 06:14 AM
CrazyHawaiian's Avatar
Car: too many ...
Maybe they put in a box with the wrong stops when he replaced it a few years ago (never know right?) Does it happen when turning both ways? I'm running 245's on my IROC and with the stock suspension it would rub only when turning one direction. The previous owner had the car aligned at Sears and they didnt align the car to the steering box, they aligned it to the steering wheel (which was put on crooked). So pretty much it turned more to the left than it did to the right. I'm still trying to figgure out how it wasnt hitting a stop.
Old Mar 23, 2005 | 06:32 PM
Cooter77's Avatar
Would you happen to have the FEA specs after your install..??
I never had this happen before I lower'd it. I replaced the steering box with a reman'd cheap one from a local parts store. But, i don't understand how this could be a problem.
I have toss out some pics of where its hitting....
Attached Thumbnails Binding while turning, please help-f-wd13.6-pic-s
Cooter77's Avatar
Another pic
Old Mar 23, 2005 | 06:37 PM
Cooter77's Avatar
last pics
Old Mar 23, 2005 | 06:38 PM
Cooter77's Avatar
What do you mean..??
Old Mar 24, 2005 | 01:30 AM
I really don’t follow, why does everyone seem to make that big a deal about a little bit of rubbing there… just don’t crank the wheel all the way over and you’re fine, you shouldn’t be cranking the wheel all the way over anyway, and it’s not like any kind of reasonable action will hurt anything.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
