Rear lower control arm mount replacments?
Old Apr 24, 2006 | 06:26 PM
SageMoonblade's Avatar
Tody I had a rather nasty shock, hearing a scraping sound I pulled over to find my passenger side rear lower control arm on the rear axle to be hanging from the axle with the body mount still attached. Note that the body mount is no longer attached to the body..... anyone know where if this part is replaceable and if so where to find them......
Attached Thumbnails Rear lower control arm mount replacments?-picture-010.jpg   Rear lower control arm mount replacments?-picture-011.jpg
Old Apr 24, 2006 | 07:38 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
whoa, either your going to have to put all new floors in that badboy, or take all the good stuff on the car and sell the rest to a salvage yard....that thing is seriously screwed up my friend.
Old Apr 24, 2006 | 08:43 PM
ok be that as it may.... the floor pan and the control arm pocket are 2 different parts..... cant seem to locate a new pocket
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Wow! That's the floorboard AND the LCA!.....stick a fork in it - it's done. I don't even see good metal to weld to under there....that's tough man, I feel for ya.
Old Apr 24, 2006 | 10:04 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
oh my looks like time for a new thrid gen sorry
Old Apr 25, 2006 | 10:49 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
HOLY HE11 !!!!
Old Apr 25, 2006 | 10:51 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
things are looking pretty bad. It looks doubtfull that you would be able to find good strong metal to weld a new mount onto. To answer your question, you won't find that mount sold anywhere separately. You will have to have one cut out of a car in a salvage yard. Likely, you'll need to have a rather large section cut out of another 3rd gen and weld it onto your body... assuming there is good metal to make it structurally sound. Realistically, there is no easy safe solution and you're best off getting another car.
Old Apr 25, 2006 | 12:02 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Yep if theres any good parts pull'm off and get rid of that thing. Find a roller in the classifieds section and put your drivetrain in it.
Old Apr 25, 2006 | 01:25 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
OMG I THOUGHT MY PINCHWELD'S IN THE FRONT WERE BAD GODDD ( bent up a bit and rusty my floors are fine though..)! lol sorry feel bad for you, Time for a new car Just dont buy an import on us
Old Apr 25, 2006 | 02:31 PM
the funny part is that for the most part it seperated at the weld points....... rusted straight through the weld..... and my other cars happen to be a 1978 bronco and a 1992 3000gt VR4 (note VR4 is up forsale. make offer)
Old Apr 25, 2006 | 11:23 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
thats the funny part, i bet they are both rusted as bad as the bird.
you can find rollers pretty cheap in the classified section.
by the way, where do you live, in the salt belt???
Old Apr 25, 2006 | 11:36 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I'd rent a small sand blaster, and a wire feed welder, clean it up and weld it back together. It's a rusty mess, but what else can he do?
Old Apr 26, 2006 | 01:52 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
Yeah, about the only you're gonna do with that besides scrapping it is clean it up as best you can and weld a plate to it to remount the lower control arm. However unless you can weld I doubt anybody is going to weld it due to possible life safety concerns.
Old Apr 26, 2006 | 06:51 AM
JB22's Avatar
That thing doesnt look safe at all man.
I would definitely be looking for another ride.
Old Apr 26, 2006 | 02:04 PM
I live in Michigan and the truck is worse off, but its just an off-road toy, the 3000gt is rust free.
Old Jan 26, 2007 | 12:26 AM
If anyone still cares about this project I have figured out that it will be hard but I plan on salvaging it if I can, cars been in my life too long to just give it up that easy, if anyone has an idea where to start wroking at would be of much help. Here is what I know, the rockers are in rough shape, door are shot, the rear fender just behind the door is rusty and dented. I want to run an all new floor in the car. Everything eles other than the tranny can be saver with a little work.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
