how do i get my centerlink off!
Car: 1991 Formula
Engine: 350TBI
I'v tried beating my centerlink out but it wont work; it even broke my rybber hammer doing it. Is their an easier way to get them off?
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: how do i get my centerlink off!
You need a heavier BFH or a pickle fork.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
make sure the car is on level surface or raise the rear and support the car on the unibody
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I had no luck with a pickle fork on the pitman--and I used a four-pound sledge. I rented a puller from AutoZone and within seconds I was good to go.
JamesC
JamesC
Car: 1991 Formula
Engine: 350TBI
The pitman arm pulled? I thought it only worked on getting it not from the gear box
Car: 1987 iroc
Seriously, a pickle fork is a wedge type fork with a handle for pounding on, used for taking apart most front end parts, ball joints, tie rod ends etc. You should use a pitman puller for the pitmam arm, which is a U shape puller designed especially for pitman's. And at least a 2lb hammer (BFH). Hope this helps.
Car: 86 Trans Am
how did we get on to pulling the pitman arm? the OP is taking the centerlink off.
Car: 1987 iroc
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Car: 89 IROC-Z & 92 RS
Engine: 350 TPI & LQ4 408 in the works
Transmission: 700R4 & T-56
Axle/Gears: stock/ LT1 disc 3.42
especially when you use one to take the pitman off the box. should probably buy another gearbox after that.
Transmission: Pro-built 700R4
Are you removing the idler arm with the centerlink? When I removed mine recently that's what I did. This way you only have to worry about getting it off the pitman arm. I soaked the pitman/centerlink bolt in WD40 and let it sit overnight. The next day I removed the idler arm bolts from the body of the car and then used the leverage from the centerlink to dislodge the pitman/centerlink bolt (after removing the nut). It dropped right out.
