I need to find adjustable sway bars for a 3rd gen.
Old Nov 12, 2001 | 02:03 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
My friend had them on his car and I like them, But I don't know who made them. Any help would be great. And I am open to any sway bar sugestions. thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 12, 2001 | 02:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How do you make a sway bar adjustable?
Old Nov 12, 2001 | 02:22 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Ground control makes the attatchments. www.ground-control.com
'91 RS 3.1
SSM SFC's
Energy Susp. Hyper-flex kit
GTA Sway bars
Clarion, Phoenix Gold, JL Audio, etc.
Pictures: ]http://albums.photopoint.com/j/AlbumIndex?u=1742507&a=13412261&f=0]
Quote: "If you can't beat them, arrange to have them beaten."
- George Carlin
[This message has been edited by REZN8R (edited November 12, 2001).]
Old Nov 12, 2001 | 05:37 PM
Hulk0202's Avatar
So what kind of adjustments is there to make? I dont see a picture on the web site. I dont understand what you would adjust.
Old Nov 12, 2001 | 07:00 PM
82camaro's Avatar
Car: 82 camaro SC
The only adjustable sway bars I've seen just have adjustable end-links. Basicly a spring that could be adjusted.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 13, 2001 | 08:07 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I haven't seen pictures, I just know it attaches at the end of the bar. replacing the end link. It allows you to somehow change the leverage of the bar so it acts stiffer or softer.
Old Nov 13, 2001 | 11:40 PM
Kandied91z's Avatar
and why would you do this? put the 1-le's on there and you'll be happy.
Old Nov 14, 2001 | 02:52 PM
BLACK Z's Avatar
Car: 86 Z28
I think it alsoha to do with when you can the ride height of you car, this way you don't have to mess with resizing teh end links. Just a guess though. This is one of the reasons I want them. Second my friend had them on his car and it handle like it was on rails.
Old Nov 15, 2001 | 01:46 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
If you don't see any point to adjustable Anti-roll bars, then don't post on this thread. :P
The point of an adjustable Anti-roll bar (swaybar) is to allow the bar to be softened or stiffened to tune the chassis at the track. Adjustable endlinks are necessary to "zero" the bar. That is to make sure there is no force on the bar when at ride height (driver in seat 1/2 tank of fuel). None of this is necessary on a street car, but it is very important on a track car.
When you get really tricky, you can have driver adjustable bars to compensate for diminishing fuel loads (among other factors) during a race.
any more questions for the smartasses?
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
http://communities.msn.com/clemsprojects
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
