Lowering your third gen?
Old Nov 9, 2001 | 10:27 AM
92Camaro305TBI's Avatar
Whats the best way to do it and keep performance. I got a couple of quotes and they said it was an eibach(spelling) kit that would lower it 1.6in. Has anyone used this kit and would it impare performance?
thanks
92 Camaro 305 TBI Automatic
https://www.thirdgen.org/rides/index...ew&rideid=6100
Old Nov 9, 2001 | 10:32 AM
82camaro's Avatar
Car: 82 camaro SC
IMO, Lowering is for performance. Sure it looks good, but I lowered my 82 for better handling. The stiffer springs and lower center of gravity are great for corners--but it will ride stiffer. A set of 4 drop springs and a performance alignment(not the stock specs) will work just fine. If wheel hop becomes a problem after the drop, a set of LCA relocation brackets will fix it.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 9, 2001 | 10:42 AM
Thanks, Did you have problems with Ground clearance? I know I scrape my cat going at up angled driveways?
Also do you have any expirence the the eibach's kit.. thanks
Old Nov 9, 2001 | 10:57 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
well since i lowered my car about an inch i have had no problems at all.. you stil scrape about the same amount but it handles much better.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets,posi 323 , lt1 cam and new valve springs
Old Nov 9, 2001 | 11:03 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Eibach Springs on mine.I ended up cutting mine even shorter, though.
Ride quality will be a little more firm, but it will handle so much better, you'll never
regret it.Eibachs are probably the most popular springs among third gen owners,and I think you'll be pleased with the way it looks
and handles after installing them.
As far as scraping, well in my opinion,it's a small price to pay for the improvements.
You'll learn to look a little farther ahead for obstructions in the road,and take speed bumps slowly, at an angle if necissary.
-Rich-
Old Nov 9, 2001 | 11:35 AM
Thanks guys, now I'm set on getting them. What did you pay for the kit and did you install them your self or have someone do it. I have little experiance under the car!
thanks again.
Old Nov 9, 2001 | 01:13 PM
cort351w's Avatar
I've heard that the front tires will wear very quickly after you lower your car. Has anyone that lowered their car actually experienced this? (not a lot of third gens around here to check out/compare) Do you have to get a camber kit to fix this problem, if it exists. Again, I'm going off of what I've heard and read on company websites.
Old Nov 9, 2001 | 01:47 PM
I haven't heard that before, However I do know that the outer side of my tires wear really bad(front compared to back) and I haven't had any upgrades to my suspen..
Maybe a kit will help that!?
Old Nov 9, 2001 | 07:04 PM
camaro6spd's Avatar
the outsides of mine wear faster then the insides and mine is lowered, but i think a front end alinment will fix that problem.
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Nov 9, 2001 | 08:25 PM
82camaro's Avatar
Car: 82 camaro SC
Just need a 'good' alignment to help stop the uneven tire wear. The stock setting suck--even you are still are at stock height.
Camber -.5 (give or take a little so both sides are equal)
Caster +4.5 left +5 right
Toe +1/16 inch
Scraping is just part of sitting low...
82camaro
Old Nov 13, 2001 | 09:27 AM
Car: 92 Camaro RS
If your car's lowered as much as mine, it'll require caster/camber adjusters of some kind.Otherwise plan on seeing cord on the inside of your front tires long before the outside wears.Mine had almost 5 degrees of negative camber before I got the adjusters,now I'm at a much more reasonable 1 degree negative,5 degrees positive caster and 1/16" Toe.Got the adjusters from Ground Control Racing.
-Rich-
Old Nov 13, 2001 | 12:52 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Stock third gens do best with 0 camber, I know it sounds weird but you'll experience better highway tracking and steering response.
Old Nov 13, 2001 | 01:31 PM
TVP123's Avatar
the best bet is Nascar 5.5" springs with adjusters .. check out Ground control once again .. they have a drop in kit .. and a weld in version .. you can start with a 3" drop and adjust all the way back to stock in in just minutes !!! great for SOLO stuff .. stock height all the way to the track ..then slammer the ***** for the race
Old Nov 13, 2001 | 09:04 PM
Would Ground control racing have a website?
thanks
Old Nov 14, 2001 | 09:00 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
82camaro,
What brand of springs is your car equiped with?
Mark
Old Nov 16, 2001 | 09:24 AM
Car: 92 Camaro RS
[QUOTE]Originally posted by 92Camaro305TBI:
[B]Would Ground control racing have a website?
http://www.ground-control.com/
Here ya go...
-Rich-
1992rs/ss
Jan 31, 2025 05:10 PM
87iroctheo
Dec 4, 2016 11:47 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
