UMI Performance 3rd Generation K-member Now Available!
Old Nov 25, 2011 | 10:09 AM
UMI Performance's Avatar
1982-1992 F-Body K-member for TPI, SBC, BBC and LSX Engines
UMI Performance is proud to announce the design of our 82-92 K-member is complete and we are adding the finishing touches now. The K-member will save 20 lbs of front end weight while freeing room for turbo set ups, headers and other exhaust items. The K-member that will actually ship will have some small changes compared to what the picture shows, the rear control arm mount is now boxed and there is a forth motor mount hole. The finished design will be rock solid.
Currently we offering four K-member options, two for the standard SBC/BBC/TPI and two for the LSX engines. I will explain each one below.
#2401- 1982-1992 GM F-Body Tubular K-member, Coil Springs
This item will work with TPI, SBC and BBC. It features bolt in spring perches for standard springs and lowering springs. The K-member will except factory motor mounts or solid mounts like UMI P/N 0051.
#2402- 1982-1992 GM F-Body Tubular K-member, Coil Over
This item will work with TPI, SBC and BBC. This item is designed to work with coil over set ups only. The spring perch bolted to the K-member in the picture will be replaced with a support brace. The spring perches can be purchased at a later date if needed to convert to factory style springs. The K-member will except factory motor mounts or solid mounts like UMI P/N 0051.
#2403- 1982-1992 GM F-Body Tubular K-member, LSX Engines, Factory Springs
This item is designed to mount a LSX engine into your 82-92 F-Body. It features bolt in spring perches for standard springs and lowering springs. The motor mounts in the picture are similar to what we will supply but not the actual mounts, they weren't completed in time for pictures. You will need factory LSX rubber motor mounts or UMI P/N 2323, solid motor mounts.
#2404- 1982-1992 GM F-Body Tubular K-member for LSX Engines, Coil Overs
This item is designed to mount a LSX engine into your 82-92 F-Body. This item is designed to work with coil over set ups only. The spring perch bolted to the K-member in the picture will be replaced with a support brace. he motor mounts in the picture are similar to what we will supply but not the actual mounts, they weren't completed in time for pictures. You will need factory LSX rubber motor mounts or UMI P/N 2323, solid motor mounts.
We are asking for 3-4 weeks to ship this time. We will do our best to have these available as fast as possible.
Thanks for looking!
Last edited by UMI Performance; Mar 20, 2012 at 08:10 AM. Reason: Spelling and correction
Old Nov 25, 2011 | 01:10 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: UMI Performance 3rd Generation K-member Now Available!
those are some good looking pieces, congrats on getting them out in time for the holidays. i'm sure there are a few members who wouldn't mind seeing one of these tucked under the tree
Old Nov 25, 2011 | 10:07 PM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
Will these work with factory lower A arms??
Old Nov 25, 2011 | 10:31 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
A quick click to their website gives you the answer. Probably took longer to type your question.
Looks great, price is pretty nice too.
Old Nov 25, 2011 | 10:54 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I am thinking about the new complete set up, with the A-Arms what a great price
Old Nov 26, 2011 | 10:33 AM
Thanks for the comments everyone, we appreciate it.
Like mentioned, stock A-arms will work with this set up.
We hope to have more pictures in a few weeks including installation pictures.
Thanks again!
Ryan
Old Nov 26, 2011 | 11:10 AM
jamieschott's Avatar
Awesome stuff here. Looks good. Cant wait to see install pics!
Old Nov 26, 2011 | 11:31 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
want someone to test it with a duramax https://www.thirdgen.org/forums/engi...dgen-swap.html
Old Nov 26, 2011 | 03:55 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
when is the coil over style A-Arms coming?
Old Nov 28, 2011 | 01:45 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Great product!
But.... is there any chance we can have custom powder coating done even at an extra price? Sometimes a change from red and black is nice.
Old Nov 28, 2011 | 08:36 AM
1fastiroc-z's Avatar
Car: 1990 IROC-Z Camaro
Axle/Gears: 10 bolt
I ordered a k member with lsx mounts and coil overs. What coil over kit do you recommend?
Old Nov 28, 2011 | 02:41 PM
lunati397's Avatar
pa racing has a good kit
Old Nov 28, 2011 | 09:45 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
This has to be the first K-Member I think I've ever seen which actually resembles the letter K.
Old Nov 28, 2011 | 10:04 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
so what is the biggest benefit for this upgrade? just weight?
Old Nov 28, 2011 | 10:13 PM
lunati397's Avatar
weight and clearances for headers turbos motor swaps
Old Nov 29, 2011 | 02:44 PM
babadioum's Avatar
Car: 1991 CHEVROLET CAMARO Z28
Engine: 6 LITER after rebuilding :)
Transmission: 700 R4
Axle/Gears: 3.23 / 9:7:1
Thanks for the extra 5% but I do not see the 15% preorder discount?
Old Nov 29, 2011 | 02:53 PM
Coil Over a-arms are coming next, they will be identical to our current a-arms but will have no spring perches.
Originally Posted by IROCtheRoad
Great product!
We can do custom powder coating to an extent. We do all powder coating in house so that isn't an issue. The problem we are having now is our current supplier now has minimum purchase pounds on the powder, so custom colors are getting expensive because we have a lot of powder left over and expires overtime. If you serious about a custom color let me know and I might be able to work it out for a charge. We have silver on hand at all times.
Thanks for the order! We have a coil over kit in the works right now and it should be available shortly. So if you can hang in there it might be ready when the K-member is completed.
Our sale ended yesterday but I will work on getting special pricing on the site for this item. We would like to get a few more pre-orders. If you are ready now send me a PM for pricing. Thanks!
Old Nov 29, 2011 | 09:25 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Sweet can't wait to see them
Old Dec 1, 2011 | 10:36 AM
babadioum's Avatar
oh I am ready, it is just that I have to make a decision in terms of oem or UMI because this part will be shipped 10K miles overseas where I am posted and the shipping price is of enormous consequence since it will be a huge chunk of FOB pricing. So can you email me (as opposed to continuing the thread here) a quote for 2401? I am hopefully expecting the same discount that was availbale few days back which was a total of 20% including an additional 5% third gen member discount; then we can look into the international shipping quote you can get for me to find out FOB pricing. Thanks so much in advance.
Old Dec 1, 2011 | 11:42 AM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
There is no mention of what these are made out of. DOM? Chromoly? Strength is a concern as always with these, so i'm curious.
Old Dec 1, 2011 | 06:07 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Says on the UMI site they are made from mild steel. Kinda need to be mild steel if they are MIG welding them (nothing wrong with MIG welding BTW). This is the heaviest constructed K-Member out there. No other K-Member has a second tube of steel in its hoop to brace the A-Arm mounts.
Old Dec 1, 2011 | 07:11 PM
The tubing is DOM. We may add a chromoly option in the future, however since the item is mostly fabricated from flat steel the tubular components would be the only chromoly part.
I hope that helps!
Ryan
Old Dec 1, 2011 | 07:14 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
I hope that helps!
Ryan
Is it cost prohibative to use chrome moly plate steel??? Seems to me its the same price for 4130 sheet as it is for A36 or SAE 1020 sheet.
Old Dec 2, 2011 | 08:19 AM
85TransAm406's Avatar
Car: 1985 Trans Am
Since 4130 plate is the same weight as mild steel plate, it wouldn't impart any weight savings, only increased cost. Remember, 4130 tubing is only lighter because you can have a thinner wall thickness with the same strength.
Old Dec 2, 2011 | 05:57 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
I'll buy that. I thought I was pretty upto date with material prices. Just looked it up and 4130 is nearly double the price of mild steel.
Old Dec 2, 2011 | 11:24 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Thanks, this looks like a great piece
Old Dec 5, 2011 | 09:13 PM
Project-RS's Avatar
Special Pricing: We offering this item currently as a preorder at 15% off and $9.99 shipping. BUT we are going even further! All Thirdgen.order members will receive another 5% off any of the four K-members above. During check out use coupon code "THIRDGEN" and get another 5% taken off!
Thanks for looking!
im very interested in this. is the sale still available on this?? im also interested in coil spring a arms
Old Dec 5, 2011 | 11:24 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
does the engine remain in the same position as OEM ? , or is it moved forward like the BMR k member ?
Old Dec 6, 2011 | 09:43 AM
We just placed the K-members back on sale under a pre-order price of 20% off. The "Thirdgen" code is no longer valid but instead we just placed the k-member at a straight 20% off.
Our K-member will keep the engine in the same location as factory, there is no moving of the engine. This way your current transmission crossmember and drive shaft will still work and fit correctly.
Thanks for asking!
Old Dec 6, 2011 | 10:40 AM
Project-RS's Avatar
[quote=UMI Performance;5113968]We just placed the K-members back on sale under a pre-order price of 20% off. The "Thirdgen" code is no longer valid but instead we just placed the k-member at a straight 20% off.
great deal. is the shipping still the 9.99 or is it different? now all i need is a sale on the a arms.......lol
Old Dec 6, 2011 | 10:46 AM
Customer will pay shipping but we increased the discount to 20% (Rather than 15% off then another 5%), it comes out close to the same.
I hope that helps!
Ryan
Old Dec 6, 2011 | 02:15 PM
85streetmachine's Avatar
Car: 1985 iroc z
Engine: 6.0L coming
Transmission: 4L80E coming
Axle/Gears: 10 bolt 3.73
Lsx kmember and a-arms ordered today Cant wait to see them.
Old Dec 7, 2011 | 05:44 AM
Engine: L69
Transmission: A4
Oh how I wished I had more money. I've saved UMI in my favorites solely because you are able to do custom colors. Kudos!
Old Dec 7, 2011 | 08:00 AM
Project-RS's Avatar
im just waiting on the ok, then i will be ordering k member and a arms
Old Dec 26, 2011 | 06:36 PM
89RJcamaroRS's Avatar
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
just ordered mine for my 92 hope this is worth the month wait. ordered mine in black planning on doin everything in umi stuff when the time comes
Old Dec 28, 2011 | 04:11 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I will be getting mine later on down the road as I just put my motor back in. When I pull it next time I will be doin this
Old Dec 28, 2011 | 05:33 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
How much does this k-member weigh?
Old Dec 28, 2011 | 08:09 AM
UMI Sales's Avatar
Currently 23.8 minus powder coat. Probably 24.4-ish after PC.
ramey
Old Dec 28, 2011 | 11:53 AM
Project-RS's Avatar
i ordered mine on the 8th. cant wait to get it so i can finish my engine bay
Old Dec 28, 2011 | 02:40 PM
We didn't forget about any of your orders. We are on this project everyday and getting close. Jerry, Ramey and myself are working out some minor issues that arose, we will be posting some updated information shortly.
Thanks!
Ryan
Old Dec 28, 2011 | 02:47 PM
Project-RS's Avatar
Thanks!
Ryan
im sure it will be well worth the wait. the parts i already installed are flawless. cant rush perfection. thanks for the update,
project-rs
Old Jan 17, 2012 | 01:43 PM
  #42
blakecharles's Avatar
dose anyone have one of these installed? they take 3 weeks to get still?
Old Jan 17, 2012 | 01:56 PM
  #43
Project-RS's Avatar
im still waiting on mine and i ordered it dec 8th. i believe they are finalizing the finish product
Old Jan 17, 2012 | 01:57 PM
  #44
We are still working on them, we had a few bugs and tweaks to work out and trying to get them into final production now.
We will keep you updated!
Old Jan 21, 2012 | 11:37 AM
  #45
Just another quick update. The k-member is heading to full production, we worked out the tweaks and fixed a few things we didn't like. The few pictures below show some of the exhaust clearance and fitment.... nothing fancy but they help give you an idea.
While the machine shop is beginning to build the production pieces the design crew is finishing up the LSX mounts.. this won't take long.
So we are getting close and want to thank everyone for the patience.
Christina, who handles all our marketing and advertising here at UMI is currently building an 85 Camaro Z28, the goal is to have it completed before mid April for the Spring Carlisle event. We will be installing and using a full UMI suspension including the new front k-member assembly. We will be posting pictures of this build soon so stay tuned!
Attached Thumbnails UMI Performance 3rd Generation K-member Now Available!-img_1535.jpg   UMI Performance 3rd Generation K-member Now Available!-img_1534.jpg   UMI Performance 3rd Generation K-member Now Available!-img_1537.jpg
Old Jan 21, 2012 | 12:25 PM
  #46
Project-RS's Avatar
i hope my full length headers dont have an issue
Old Jan 21, 2012 | 05:19 PM
  #47
toomanytoyz's Avatar
Car: 89 Formula - LM7 Swap in Progress
Engine: 5.3/LS1 cam & Intake
Axle/Gears: Aussie 3.27
Man, I still want in on this, Ryan... I think it was my turn to respond to the email we had going. I dropped the ball. lol. Was one of the "tweaks" fixing the AC compressor clearance issue?
Old Jan 21, 2012 | 05:57 PM
  #48
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Expect a call from me on Monday. I'm gonna order a SBC K-member and A-arms for coil springs. All in black. Thanks for making quality parts.
Old Jan 23, 2012 | 09:37 AM
  #49
A long tube header shouldn't cause any issues at all, there will be plenty of clearance for this so no worries.
In order to run A/C with our LSX k-member you will need to find a truck A/C unit or something that bolts into a different location. The other option and best option would be a relocation kit like Kwik Performance sells. This will relocate the A/C to the top and away from the k-member. After some time we are unable to include A/C clearance with our design with out effecting the integrity of the part. Also after some research and speaking with some customers many people ditched the A/C when doing this swap, many mentioned the challenge of running the lines and converting it was too much. Others mentioned they had no desire for A/C. So A/C will work if relocated upward, we figured if you are going to the extent of this swap a few extra dollars to relocation the A/C shouldn't be an issue.
Thanks again!
Ryan
Old Jan 23, 2012 | 10:27 AM
  #50
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Any problems running Dyno Don's headers with this K member?
