Front lower control arm bushings removal
Old Jun 8, 2013 | 11:21 AM
whatdayasay's Avatar
1. Is the sleeve that I see between the two control arm plates the sleeve of the bushings? Therefore I can cut it with a recipicating saw (sawzal)?
2. Why do some try to burn out the rubber? Is it so they don't have to saw thru the inner bushing sleeve?
3. I make my 2 cuts on the outer bushing sleeve perpendicular to the sleeve and in between the control arm plates and then just press out the ends or cave in the ends and tap them out?
Old Jun 8, 2013 | 11:34 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Front lower control arm bushings removal
The Shop Manual Says They Should Be Removed With An Arbor Press.
Old Jun 9, 2013 | 01:04 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
get a balljoint press. it's like a really heavy duty c clamp.. they will slide right out and the new ones will slide right in.. just make sure you make a spacer to put in the space between the "legs" of the arm that the bushing presses into to keep them from collapsing..
Old Jun 9, 2013 | 10:17 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Good luck pressing out 30 year old bushing sleeves without mega press and heat. What appends when you apply adequate heat? The rubber burns.
I burned them out then cut up the sleeves so I could collapse them inwards.
Other posters are correct that the critical part of the pressing in or out is proper spacers and drivers or you will bend the arms, true for rear arms too.
Here's mine with new bushings pressed in.
Old Jun 9, 2013 | 10:53 AM
How many spacers do I use. I've been using parts from my ballpoint kit as spacers. I bent the arm legs without the spacers and bent them back, I hope the legs don't have to be perfectly bent back.
Old Jun 9, 2013 | 10:56 AM
I bent my control arm legs trying to press them out, but bent them back. Will that be okay?
Old Jun 9, 2013 | 09:20 PM
stealtht/a's Avatar
Guess it depends how badly bent they were. Bending will fatigue the metal and possibly cause weakness, but it should be able to handle a little bending. Check for any distortion or stretched areas.
The right number of spacers is enough to keep the arms from moving. I have a bunch of random steel blocks and shims I use for my press. I just lightly jam them between the arms so there's no slack.
Old Jun 10, 2013 | 01:29 AM
I just wondered if I didn't get the legs bent exactly back to shape it wouldn't work right.
Old Jun 10, 2013 | 04:52 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
As long as your close to the original position it will be fine.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
3rdgenparts
Aug 8, 2015 07:09 PM
