Everyone with the EIBACH Pro Kit Post your pictures!!
Old Mar 19, 2002 | 03:41 AM
Jono's Avatar
I'd like to see as many pictures as I can, I don't want to go as low as the sportlines and I'd like to see as many pictures of the pro-kit before going with it. I've searched the boards and seen a few but I want more! Thanks guys as you can see my car is squating on its ***, it's just wrong and must go come April!!
I would like the height equal to what the rear is at now do you think the pro-kit will give me it or will it be like the front?
Old Mar 19, 2002 | 04:27 AM
JPrevost's Avatar
Car: 91 Red Sled
Mine are on my website.
Old Mar 19, 2002 | 09:40 AM
Steve89GTA's Avatar
And where would that website be? I'm interested in the same springs. Should the isolators be changed as well? What else do I need for a spring swap
Old Mar 19, 2002 | 11:49 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
In my -85 z28 with pro-kit ,dimension at rear from center of hub to fenderlip is 370mm,and same dimension at front is 365mm.
Old Mar 29, 2002 | 04:58 PM
88 IROC BOB's Avatar
Jono, I like you're look better than mine. I've got the jacked up in the rear look (which isn't a good thing). The fronts have sagged badly.
I too am looking at the Prokit and new shocks along with some new LCA's and relocation brackets.
Bob
Old Mar 29, 2002 | 06:22 PM
iroc22's Avatar
In the profile
Old Mar 29, 2002 | 07:58 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Here's mine...
Old Mar 29, 2002 | 10:37 PM
Steve89GTA's Avatar
Any problems with jacking? My car is just barely high enough now to easily allow my jack under there. How do you guys jack it up otherwise?
Old Mar 29, 2002 | 10:41 PM
Humvee's Avatar
My car got a saggy rear with the front sitting a bit higher. It disgusts me quiet a bit... I've heard a couple of times that if you get the Pro-kit, it might not change the height of your car as it is now except to even it out since the stock springs are already sagging, giving you a slight 'drop'. Dunno... Anyone can clear this up? I've been thinking about dropping my car ever since I got it, but there is a speed bump that I scrape on every dang time on the way to college. Any lower, I'd probally high center on it!
Humvee
Old Apr 2, 2002 | 12:14 AM
Jono's Avatar
i really like that firebird, and the height is so perfect its complete symettry. The wheel well and tires match so nicely, I'm definitely getting the pro kit soon. I don't like the look that happens when the tire goes under the wheel well, like some of those slammed civics and stuff, its just ugly. That firebird is so nice.
Old Apr 2, 2002 | 08:35 AM
cg91ta's Avatar
My stock springs were saggy, and I only saw a 1/2"-3/4" drop. but it leveled it out very nicely. I immediately felt a handling improvement.
I have a 3 ton floor jack and it doesn't fit under the front since I lowered the car. I usually take a bottle jack and slip it under the a-arm first. Otherwise I have a decent set of steel ramps with extensions that I got from AutoZone that work very well.
I don't have any problems with small to medium speed bumps, as the spring rate is good. The larger ones I slow way down. Oh, and watch the driveways, hit 'em at an angle.
I like what the kit did for my car in both appearance and handling. Get a 19, 20 and 21 mm 1/2" drive sockets and the same size box end wrenches, it will make the task much easier. I took the shocks off (I replaced them at the same time) and dropped the a-arm down and out popped the spring. The rears were super simple. Just follow the instructions in the Chiltons manual and you'll have no problems.
Good Luck!
Old Apr 2, 2002 | 08:38 PM
Bort62's Avatar
Careful you don't Catch it In the Face.
You don't need a spring compressor to do this job, but put your Jack under the A-Arm while you losen everything, and let it down slowly. Then pop the spring out with a crowbar from a position where it can't hit you... Like around the front of the car.
There is a LOT of force pent up in those compressed springs, You will see when it does finally "come free."
Old Apr 2, 2002 | 09:49 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Well I don't plan on lowering my car any, but I do know some of the guys w/ 'em, place some 2x4s in front of their tires and drive up on them; then they use a jack. Hope that helps.
Old Apr 2, 2002 | 10:50 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Gunny: That's a great idea, thanks for the suggestion!
Old Apr 2, 2002 | 11:53 PM
cg91ta's Avatar
Correct about the jack. Like I said, follow the directions in the Chiltons. I never had the springs (new or old) come flying out, but then I was using a bottle jack that works very well at s-l-o-w-l-y backing down. Usually I had to bounce the a-arm with my foot to give it an extra 1" to free the spring. If I'm not mistaken it took me less than 3 hours to do all 4 corners (shocks, struts and springs).
Old Apr 3, 2002 | 12:49 AM
Bort62's Avatar
I have to Drive my car up on about 4" of Ramp to have any hope of Getting my Crafstman 3 Ton under the K member.
Its a REAL pain in the ***. And when the fronts jacked up, You can forget about the rear.. and Vice versa. Getting the Car up On 4 stands is a Long process of little here, little there...
Mine is lowerd 3-3.5" Tho.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Linson
Aug 21, 2015 02:12 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
