Should I get this (Ebay)
Old Oct 22, 2003 | 12:58 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
http://cgi.ebay.com/ebaymotors/ws/eB...category=33553
I have heard some people talk about a spacer but is this the one???
Old Oct 22, 2003 | 01:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Save your money. It will not allow 15% airflow. If you are trying to squeeze every last cfm out of the stock TBI than go for it. It is really cheap, they usualy go for 20 but I would use that money towards something else.
Old Oct 22, 2003 | 02:10 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
What is the spacer that you have???
Old Oct 22, 2003 | 02:24 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The spacer that I have is a .5" TBI spacer. It sits between the TBI unit and the intake manifold. The only reason that I have this is to get my open air element to clear the top of my distributor. They can add meassureable power to carb applications but I doubt they do anything for the mighty LO3. What you have found on ebay there is a spacer that goes between the injector pod and the TBI unit. It sorta backs your your injectors from being to deep in the TBI unit allowing a little more air in.
Old Oct 22, 2003 | 02:38 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
Just double the injector pod gaskets. It works just as good and is cheaper. I even got a extra gasket from the junkyard for free! Thanks, Bobby
Old Oct 22, 2003 | 03:02 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
did tbis not come from the factory with that spacer? im asking because every tbi ive seen has that exact same spacer. my car had it when i bought it. and when i got my metering assembly at the bone yard, i watched the man remove it from the base and it had a 1/4 in spacer also. i was gonna get it too but he broke it trying to remove the assembly. so did tbis come with these spacers, or is it just a coencidence that the tbis ive seen had them them previously installed?
Old Oct 22, 2003 | 03:12 PM
vjo90RS8's Avatar
Car: 2002 Z28
that is not the 1/4" spacer, it is an 1/8" gasket. Thats why people just say add another gasket.
Old Oct 22, 2003 | 03:18 PM
Car: 91 RS
Engine: LO3
okay. i never measured and it seemed bigger than 1/8in. now i know. thanx
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
GageBrand
Oct 22, 2015 02:30 PM
okfoz
Oct 13, 2015 02:19 PM
