My Plans... Need Input
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
So im looking to go low 14s on 305 TBI(dont tell me it cant be done because im gonna do it)
i want to go with #882 casting heads or L98 heads with crane 1.6 rockers, custom grind mild/hot cam, 1 5/8" headers, full exhaust, 373 posi, street/strip shiftkit stage 2 b&M
What do you think?
What do you think?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
14's can be done but I would read the sticky at the top of the page devoted to TBI newbies. It should tell you what go fast parts you need to consider.
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
Thanx but im looking for ways to improve on my setup... if anyone has a desktop dyno that they could plug some stuff in for me that would be great let me get some specs on the cam tonight.
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
That is exactly what im tryin to do i wet through jegs an summti nad searched and used my bootleg desktop dyno and came out with a 379 (@ 45000 rpm) footpounds of torque 370 hp (@ 6000rpm) engine (at the fly) for about $2233.92 and with a 2500 - 2800 stall converter 3.73 or mabey 4.10 posi rear and some drag radials mabey street slicks iddny profiles sportsmans or whatever you can probly ru na nice 14 or 13 then to brake the 13's shifty said i should stiffen the chasi some sub-frames and probly more stuf dealing with putin that power on the ground
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Also when doing exhaust, keep a cutout in mind. what intake do you plan on running 90formula?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
its all going to be in the cam, with a 4bbl intake, a 670 TB unit, ported l98 heads (the only issue here is compresion, what are you going to do to make up for the compresion loss?) with descent cam, and proper tuning, 14's is easy, i am pretty confident my combo will run 13's.
Car: 1990 Camaro RS
i think that is a better match for your combo than the L98 heads, if there is a flow diffrence (i think the ports are the same on both) the compression diffrence would make the 305's the better choice.
Linson
Oct 1, 2015 09:50 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
