Average track times for a stock 305
Old Aug 9, 2004 | 12:33 AM
1SiC88's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
I am running 16.6 in my stock 305 TBI @ 2300 feet. (Here in Vegas)
I was just wondering what any of you other 3rd gens are running stock and what if your elevation.
I am also an atuo with no posi and I just wanted to see some other stock times before I start modding the car.
Old Aug 9, 2004 | 12:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome abaord man. You will find that most stock LO3 cars run anywhere from 15's to 17's. State of tune, mileage, suspension condition and other factors really put a toll on low ET's. Most well running LO3's without worn suspensions can run low to mid 15's.
Old Aug 9, 2004 | 03:27 PM
1SiC88's Avatar
Car: 88 Camaro
Engine: 305 TBI
Thanks for the welcoming.
YA, I understand that. It is a 305 TBI with 72k original miles on it with an auto.
I am cutting 2.2 - 2.3 60 ft's and running the best of 16.6 @ 79.8 mph.
Old Aug 9, 2004 | 04:27 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Your 60' are half way decent so I would try to maybe shift at a higher RPM. The tachs in these cars are really off. You can use a scan tool or an aftermarket tach to see how far off it is. Some guys have picked up .5 sec by letting it rev a little higher. Some tachs will read 5k+ and really only be around 4100 rpm or so.
Old Aug 9, 2004 | 04:51 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I'd also say give it a good full tuneup. Your trap speeds are a little low I think. You could probably gain some just by tuneing it up completely.
Old Aug 9, 2004 | 11:07 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
i got a 92 rs with an lo3 with 170,000miles, a hurst 5 speed and i have flipped the lid on my element with a taller filter, no exhaust past y pipe (which i do not recommend, its only temporary), hypertech chip, and 3.42 limited slip rear and i run 15.6 at 92mph. those 5.0 HO mudstains don't know what to think.
PS. don't worry the car is in storage till i get the new exhaust so i don't fry pistons with the exhaust the way it is. edelbrock headers and borla catbacks aren't cheep so it'll be a while before i get to drive it again
Old Aug 14, 2004 | 08:19 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
try running these cars at 2300' thats the times you will get,my Lt1 m6 runs 14.30s up here and at sea level it runs 13.8s nothing done but a flomaster.
Old Aug 15, 2004 | 12:28 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Well, when I first bought mine it needed a tune up badly and the muffler was hanging off of it. I took it to the track the next day and bested a 16.1 with it.
Went home and to my friends shop, had him do my exhaust...ordered a couple parts...and did a nice full tune-up and I bested a 15.29 after that.
Old Aug 15, 2004 | 03:25 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Re: Average track times for a stock 305
I dont think that time is bad at all for the elevation, plus i know it was hotter then hell. What was temp. when you got that time? I spend a lot of time in vegas, and temps past 115* arent uncommon.
Azrael91966669
25
Jun 20, 2017 04:04 AM
marcusaw
Aug 10, 2015 08:13 AM
Thirim
Aug 9, 2015 06:19 PM
Leggman1
Aug 6, 2015 04:15 AM
