L31 with TBI, I'm confused
Old Feb 25, 2006 | 10:04 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
I have a L31 (Vortec heads, you already know that though). It's going into my 86 Sierra. I want to use TBI, and I have a 2" throttle body that was used on a 4.3 Chevy boat engine. It's an actual Rochester throttle body.
So, I need some suggestions on how to get this throtte body to work with this engine. I looked at the GM Vortec to TBI intake manifold, but it doesn't look like those are 2" bores for the TBI. I'm thinking of using a carb manifold and using an adapter plate, but I'm a bit confused about what manifold ot use. Back when I was on the TBI board alot, I remember everyone saying to use a single plane over a duel plane intake. I did some searching and didn't find anyhitng on this.
What do you guys suggest I do?
Old Feb 25, 2006 | 10:37 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
go dual plane and buy an aftermarket carb manifold then get the tbi adapter plate for it. Something like the performer rpm or weiand stealth would be good.
Old Feb 25, 2006 | 11:30 AM
DM91RS's Avatar
Car: 91 RS
RPM Performer and adapter plate is working well for me.
Old Feb 25, 2006 | 01:21 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Thanks for the help guys!
Is it true that the factory cam in the L31 is actually a LT1 cam? Just curious.
Thanks again!
Old Feb 25, 2006 | 07:22 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Thanks again!
B-Body LT1 cam.
Get a carb intake and a holley projection adapter.
Old Feb 26, 2006 | 11:32 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
I looked up the specs on the LT1 cams and to me, it looks like I'd be better off sticking with the B-car cam because it makes more torque, which is what I need in a truck that's primarly used for towing.
I ordered a Perfromer RPM intake and a Pro-Jection adapter plate. Now I just gotta tune the damn thing!
Old Feb 26, 2006 | 11:34 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
B-Car LT1 cam=Vortec cam. They are the same thing, just the vortec uses a shorter dowl pin because it lacks an optispark.
The Iron LT1 heads=vortec heads.
Ever notice that they both have around 260 FWHP @ 4,600 rpm and 330 ft/lbs of torque at 2,800 rpm.
The F-body LT1 cam makes plenty of torque and boost HP. I have run it on a stock 350 ECM, a little more fuel pressure, and about 4* timing advance. Pulled anything I hooked to the 7,000 lbs capacity hitch. Including a 1994 chevy truck on a tandem axle trailer and an extra engine on that trailer. That was with 3.08 gears, P 255/70/R15s, 700r4 in 3rd gear, and running about 60 mph and about 2,600 rpm. Maintaining lockup was not a problem, the cruise held 60 easily, and the engine was very responsive even with total weight approaching 11,000-12,000 lbs.
Old Feb 26, 2006 | 11:43 AM
DM91RS's Avatar
Car: 91 RS
I have a 350 cop car cam. Is it similar the these?
Old Feb 26, 2006 | 07:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The L98 cam is similar to the LT1.
Old Feb 26, 2006 | 09:44 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Unfortunatly my little project is looking to be way too expensive, especially since I still need so many parts to get my RS up and running yet again. I'm just going to put a new L05 in the Sierra. For towing my boat or the RS, it'll be plenty of power. Plus I won't have to mess with the programming.
Thanks for the help anyway!
Old Feb 26, 2006 | 09:49 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I feel your pain. I am putting the GM 12514811 which is the stock L05 for Medium Duty trucks into my van. I am picking it up tommorrow night. It really doesn't cost much more if you can get ahold of one. It is being discontinued from GM. It has a forged crank, forged rods, 4 bolt mains, larger diameter pushrods, mild stock ECM compatible cam, 8.7:1 compression ratio, 210 FWHP @ 3,800, 315 ft/lbs @ 2,800, and sodium filled exhaust valves. It is rated to pull like 20,000 lbs GVW in a C60 truck.
Old Feb 27, 2006 | 05:18 PM
DM91RS's Avatar
Car: 91 RS
Why ya changing engines for now Fast?
EDIT: nevermind, I missed your other post. Bummer
Old Feb 28, 2006 | 12:26 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
I can't find that engine anywhere. I found the heavy duty version, but since it makes less power, I'm not interested. I'll be fine with the light duty L05, it lasted forever in my 89 Suburban and towed good enough. The pickup is lighter anyway.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
Glowsock
Sep 11, 2015 11:09 PM
