Attn. Pablo and all who are using a torker2
Old 02-18-2001, 03:40 PM
Zac's92's Avatar
I am looking into getting one soon like tomorrow. I only saw them listed for 86 and earlier. Did you guys just elongate the center holes to fit 87 up iron heads?
Zac Spalding
Old 02-18-2001, 03:42 PM
Zac's92's Avatar
also what tbi to carb plate did you use?
Old 02-18-2001, 03:59 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
im using heads from an 86 so i didnt have to mess with the manifold
the adapter plate is the turbo city peice, I had to grind on it for hours to use the bigger throttle body but it just about fits fine for the smaller one, youll need to notch the outer edges of the intake flange just slightly but it wasnt a problem for me
youll also need to do something about fuel lines cause the stock ones will hit the back of the plate, might try some creative bending i just used a short section of rubber line (I never said my car wasnt a hack job )
uhhh oh youll have to lose the pcv too because youll need to run your power brake hose to the pcv port on the throttle body
not a problem for me cause i have two big breathers
Old 02-18-2001, 10:51 PM
Zac's92's Avatar
I can get away with elongating the holes can't I? I'm not understanding what you mean by notching the intake flange can you elaborate.
Zac Spalding
Old 02-18-2001, 11:51 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The 2" throttle body is a bit wider than the flange on the opening on a carb intake. Correct me if I'm wrong, Pablo, but when you say "notching the intake flange" you do mean grinding away where the throttle body bores overlap on the edge of the intake flange, right?
-Mark W.
'88 SC Camaro w/ 305 TBI
Old 02-19-2001, 02:06 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i have one for sale if you would like it, i just bought one that is powdercoated. Email me if you are interested. Its clean and looks great, just isnt powdercoated.
Ive been told that the center 4 holes need to be elongated.
Am i going to have a problem grinding powdercoated aluminium? will it chip or what? i am now worried about this part of the install. thanks
Old 02-19-2001, 09:32 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
i was talking about the stock throttle body
the stock throttle body is just ever so slightly larger than the width of the intake youll need to just grind just a small bit out of the intake flange so that there is no ledge for the air to run into
the 2" throttle body is another story alltogether, i had to grind the adapter plate such that it angled inward along with the notch i ground in for the original small throttle body
youll see what i mean when you get it
Old 02-19-2001, 05:10 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Hey, snflupigus, i might buy the torker 2 from you, but what is involved with elongating the holes? and what is the difference between powdercoated and not? Will this manifold fit on vortech heads when I put a vortech 350 in there later on? thanks
Pat Hirsz
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
Run a best of 16.7 @85mph before gears
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old 02-19-2001, 09:47 PM
Zac's92's Avatar
vortec heads will not fit on a torker2
Old 02-19-2001, 09:59 PM
Car: 88 IROC
Transmission: auto
I'll probably go with the rpm air-gap then.
Get Blown ?
11-09-2000 02:41 AM
rsilver
11-08-2000 04:17 PM
GhoSSt
10-19-2000 01:54 PM
SeanSullivan
10-16-2000 09:12 PM
Quick Reply: Attn. Pablo and all who are using a torker2
