Throttle Body
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
Throttle Body
I want to upgrade t.b.'s. should i use the turbo city high flow, or the holley 670 cfm throttle body. which one of these would be better if i am going to build a 350 and bolt my tbi setup ontop of that. thank you
twells
twells
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you are going to a 350 than the Holley 670 would be great. but it is to much for our 305's. The turbocity one looks like your best bet. Also you can get a 454 off an old truck but I would spend the $ on the turbocity one because it is new. They have matched injectors and bigger bores. and they look good to. I think you have to send them your old on though...don't you. Hope you don't need your car for a week or so.
1990 RS 305 TBI T-5
.5" turbocity spacer
Summit 14X3 OpenElement W/k&N
Custom Exhaust
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/26,000 miles
1990 RS 305 TBI T-5
Custom Exhaust
Car: '90 RS
Engine: 377 LSX
Oh by the way, what other mods to you have. If you are keeping the 305 than spend the money on other stuff right now. You won't need more fuel unitl you have intake, heads, cam etc.....
1990 RS 305 TBI T-5
Custom Exhaust
1990 RS 305 TBI T-5
Custom Exhaust
I upgraded my TBI from Turbo City. I was going to use the Holley 670 cfm at first but when I talked to Holley they told me it would not work on an automotive application because of the programming difference between the cars and trucks. That one is designed to work with the trucks emissions settings.
'89 305 Formula TBI. Hedman Shortie headers, Flowmaster 80 series muffler, Jet Stage II chip, 160 thermo, Jet underdrive pulley set, Edelbrock TBI intake, 1/2" TBI spacer, Injector spacer,adjustable fuel regulator, flow matched injectors, Edelbrock TBI strut tower brace, Hotchkis panhard bar, lower control arms, subframe connectors, Bilstein shocks,MSD ignition, Edlebrock 14" open element air cleaner with K&N filter and K&N filtercharger, Auburn 3:73 Posi with Richmond gears
LOL. Sorry, I have to laugh, but don't listen to Holley when they say crap like that. It's just to cover their butt. You can use the Holley and it will work just fine with our cars. Maybe not in this situation, but just to clear it up, they are compatable with our cars.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
wait a little bit before buying either. Im pulling off my 454 throttle body and putting the 1 11/16 one back on so that when i get my prototype made soon i can flow all 3 of them together. I wont have flow #'s on the holley or the turbo city unit, just the rochester 454, and the smallblock tb.
Im not kidding people, im going to build you all the best damn throttle body youve ever seen.
I go to the machinist tomorow, (after rounds of phonecalls setting up a meeting again) to talk costs, and time frame.
Im in touch with a lawyer who is going to get my set up with a limited liabilty company, and I have friends in the patent office who are helping me thru that route. All this should come together by the end of the summer. So i say, seriously, if you can, wait to buy any unit, because mine will be the best.
I go to the machinist tomorow, (after rounds of phonecalls setting up a meeting again) to talk costs, and time frame.Im in touch with a lawyer who is going to get my set up with a limited liabilty company, and I have friends in the patent office who are helping me thru that route. All this should come together by the end of the summer. So i say, seriously, if you can, wait to buy any unit, because mine will be the best.
Car: 91 Red Sled
All this talk about TB's. The Holley Unit is a 454 unit modified a little. The injector tower is a little different and they use cheaper injectors than GM and turbo city. I do like the idea that I can adjust fuel pressure while the car is running (holley 670). One thing that was a pain in the *** was the connectors. You'll need to do some custom wiring for the TPS and injector wires. I'm just happy that it's 2" bore, large injectors and feeds my 350 enough to get great gas milage and good performance. Gotta love the fact that the computer automatically calibrates the TB injector speeds unlike carbs.
Can somebody post the differences between the Turbocity, holley, and GM 454 unit. I'd like to see detail pictures and explinations.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
, Jon (350 TBI!)
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
hmm, since i have a few of those little tbi i think i can arrange something.
if somebody wants to send me a holley unit for testing and a turbo city unit, i will pay to test them all!!!
if somebody wants to send me a holley unit for testing and a turbo city unit, i will pay to test them all!!! snfu, what type manifold are you going to use with your prototype TBI? ...bob
91 camaro RS L03 convert,
t-5, ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah holley is a useless bunch of a$$holes as far as i am concerned. they are NO HELP AT ALL when it comes to putting those throttle bodies on our cars. dont listen to them, it will fit.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - TBI, MSD ignition, SLP exhaust
700R4 - 2,400 stall converter, vette servo
10 bolt - SLP zexel torsen differential, GM 3.42s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
well, i have a torker2, so thats what it will be on if im the one testing it.
but i dont think i should test it on my 305, since i dont really need a bigger tb. I am however thinking of getting a new engine, its a money issue right now. i also have a few modded and one supercharged 454ss guys ready to test for me. so, whatever they got, is what it will be tested on.
ALSO, my machinist does other racing work, spacers etc.. he has a friend that has an engine dyno, and i could probably have him throw one on one of those cars, i just need to get a spare ecu etc.. those are cheap though.
o, and i also figured i would just have the throttle bodies flowtested alone on a bench too.
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
