Why is there a bolt pulging this hole?
Old Dec 14, 2001 | 12:49 PM
un4givin89's Avatar
QUestion!! I bought my new water pump and the new one has a tube on the top. It matches the stock perfectly, except the stock one has a plug on the top with a SQUARE head. Now I don't know about you, but while flipping through my manual i noticed a hose going to that in some of the pictures. But my car never had a hose going to it. WHAT THE FRICK??
Now understand Capt. Planet did a hack job number on my car, I won't even go into detail on the wiring job, gssh, but looks like someone tried to fix the water pump before, won't mention the nails. And then there was no F**ing theremostat in the car.
Anyone have any thoughts or idea on this one??
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
Old Dec 14, 2001 | 12:52 PM
fast_broker's Avatar
Typically used as a heater hose return line OR a thermostat bypass line, if needed. It is an INPUT line to the H2O pump.
Old Dec 14, 2001 | 01:57 PM
JPrevost's Avatar
Car: 91 Red Sled
Yep, old school heater hose return line. I have a tech article about how to do it on a thirdgen to get rid of the stupid heater switch.
, Jon (350 TBI!)
91 Red My website
Old Dec 14, 2001 | 03:02 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
That's how I have my heater core hooked up. The coolant supply comes from the front of the intake, and returns to the water pump. I've been told by some old-school motor-heads that this is a better way of doing it, and some how the heat will work better. I really have no idea if that's true, but I had to run mine like that since the Holley intake I have doesn't have the rear water cross-over.
Old Dec 14, 2001 | 03:09 PM
It works better because you have the coolant "push" from the intake manifold area, through the core and the coolant "pull" from the pump at that hook-up location. Efficiently and ALWAYS have good flow through the heater core.
Old Dec 14, 2001 | 03:25 PM
Nitroburn's Avatar
JP, do you have that article handy? I'm about ready to put my engine back in my car and would love to eliminate some of those "EXTRAS" that lay on top of the motor!
Mike...
89 T-Top Firebird 305 TBI Project Car (with approval from my wife!)
Old Dec 14, 2001 | 03:48 PM
DM91RS's Avatar
Car: 91 RS
You guys have come through again without me even having to ask the question.
I have a Howe aluminum radiator to install that does not have the heater return line on it.
All I have to do is pull the plug out of the top of the pump and run the line to there if I understand correctly.
91 RS 5.0 TBI...Vortec heads...Edel Performer Intake...LT4 cam...1.6 Crane golds...TES headers...3"Dynomax exhaust...5spd... 3.08...Ultimate tbi...afpr...ZR 255-50's...Koni's
Old Dec 14, 2001 | 04:19 PM
un4givin89's Avatar
Damn, I've got a return line on my radaitor and a coolent bypass and a line coming outta the back of my intake. Guess I'll have to pulg the hole huh
un4givin89
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
