Oil Pressure Problems
Old Dec 22, 2001 | 05:06 PM
vinay's Avatar
Hey, My car (Camaro RS 1992 305 TBI with 44K MILES) shows Low Oil Pressure when ever the temperature is about 200+ .. The meter is almost at 0 so I checked the oil level and it is just fine, can anyone tell me why this might be happening? The pressure is just fine when ever the car is started in themorning or when ever the engine is cold!! It is running on Mobil 1 {5w 30}.. and I change the oil and filter every 3000 miles.. Any ideas about the Problem??
My car has a Open element and Flowmaster 80 series catback and also "ultimate TBI mods" so Do you guys think it has atleast 15 to 20 more Hp than stock and what would the torque be?
Old Dec 22, 2001 | 05:34 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Sounds like the oil is thinning out too much, but no one else seems to have any problems. Is the engine stock? Maybe try 10w30.
I'd say you'd be lucky if you got that much out of those mods. A good set of heads makes about 40-50 hp, so 15-20 hp just from TBI mods and exhaust seems like a stretch.
Old Dec 22, 2001 | 11:31 PM
vinay's Avatar
Thanks Man, I was just wondering about the Hp... I thought shaving the ridges on the TBI also the the throttle plates and installing a open element and a cat back would help about 15 hp!! I live in KY and the temp here goes to about 30-50 so do you think its better that I should get 10-30 instead of 5-30 which im currently using?
Old Dec 22, 2001 | 11:33 PM
vinay's Avatar
except for the above mentioned things everything else is stock! so if the oil is thinning, doe sit result in serious engine damage???
Old Dec 23, 2001 | 04:04 AM
DM91RS's Avatar
Car: 91 RS
Is this reading on the stock guage? I don't trust those and have installed Autometers particulary for oil psi and temp. You might hook a direct mechanical oil pressure guage up even a cheap one just temp to check it for peace of mind before you go changing anything else.
Old Dec 23, 2001 | 04:29 AM
vinay's Avatar
All the gauges are stock and I i even checked the oil level about an hour ago and it was just fine and the pressure was also fine as the eingine was cold!!! the problem exists only when the temp gauge is on or above 200
Old Dec 23, 2001 | 05:41 AM
DM91RS's Avatar
Car: 91 RS
Mine idles at 25 to 35 when hot. I'd think near zero would be a problem since you only have 44K. Mine is at 150K right now
You might try installing a 180 t-stat to keep the eng running cooler overall. Just make sure that the fan will come on when needed to support that temp.
Good luck!!
Old Dec 23, 2001 | 07:27 AM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Stick to the Mobil 1 5W-30. It will provide all the protection you need and the thinner viscousity will help the engine turn easier. When you check the factory gauge be sure to check the sending unit. If you had a few bucks, I would replace the sending unit right off and see how the gauge reacted. In my experience, the sending units are more often the problem rather than the gauge itself. If you replace the sending unit and gauge and still have almost zero when hot, then you're going to have to disassemble and check your oil pump.
Old Dec 23, 2001 | 04:31 PM
vinay's Avatar
Thanks Dm and Paul!!! Hey Paul can you tell where I find the sending unit in my car? and also what do i have to do with it? i mean how to see if its working well or not?
Old Dec 23, 2001 | 06:01 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
The sending unit is usually above your oil filter adapter. I have a Caprice but F-body should be the same. It will be screwed into the block with a wire coming from it. BUT BE CAREFUL, YOUR KNOCK SENSOR ALSO SCREWS INTO THE BLOCK. Knock sensor is not near oil filter though.
I cant tell you how to test it electrically. Mechanically, you'd have to set up a pressurised system. I,d just replace it.
Old Dec 26, 2001 | 02:21 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
For what its worth, the suggested oil for these engines is 10w30.
These oil pressure sending units are flaky. I'm about a mood swing away from replacing mine due to abnormal readings and a suspected oil leak.
I don't know much about oil viscosity, but unless someone else can make a better case I'd change the oil first, change the sending unit second.
Just my .02
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
