IAC Relearn
IAC Relearn
Did TBI IAC relearn and idle drops from 1200 to 650. Restart engine and idle goes back up. Change IAC and relearn again. Same thing. No vac leaks. Excellent fuel pressure. Fuel pressure reg is good. Throttle stop screw has never been touched. ECU issue? Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: IAC Relearn
Was this a problem before touching throttle blade adjustment screw ?
if it was and no vacuum leaks could be cts false readings. Can ohm cold and hot to see readings vs coolant temp. Datalog wil see iac movement and cts the ecm is seeing.
Re: IAC Relearn
i went though the same thing with an lt1 car. it wanted to idle at 1100 or so. i plugged off all vacuum stuff and swapped out most of the related sensors with known good components, even injectors and tb. wound up being the ecu. not saying that will be your issue, but it was with me.
Car: check
Engine: check
Transmission: check
Re: IAC Relearn
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: IAC Relearn
Re: IAC Relearn
Actually working on a 90 Silverado guys. Thought it was same as the TBI set up in my Camaro. Apparently they are not. Thanks for the responses.
Car: check
Engine: check
Transmission: check
Re: IAC Relearn
I do know that the f-body '8746 ECM won't control the idle speed until the engine is up to temperature. IIRC, the truck '7747 is the same way. Up until then the max idle speed is limited, but can still be rather high.
RBob.
Re: IAC Relearn
The relearn on the Silverado is to jump the AB ports. Wait 30 sec. Then unplug IAC. Turn key off. Disconnect AB jumper. Start engine and warm up. Shut engine off. Reconnect IAC. This procedure brings idle to normal. But the next time the engine is started the high idle returns. I've ruled out the IAC itself by replacing it. And coolant temp sensor and thermostat. Thanks
Engine: Lb9
Transmission: M20
Re: IAC Relearn
