drinking gas !!!!!!
Old Apr 16, 2002 | 11:16 AM
speedfreaker's Avatar
drinking gas !!!!!!
yes i know its a v-8 and they do go through gas quick but i fill up my car everyday and recently have been taking it real easy on it "no more then quarter throttle" and i still find my self at the gas station filling up everyday is their anything that could be causing poor gas milage rich carb, vacume leak maybe someone with a vacume diagram on my motor, maybe the intake i put on, bad plug wires ????
please throw me some ideas or personal experiences cuz its really starting to hurt my wallet
Old Apr 16, 2002 | 12:02 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Re: drinking gas !!!!!!
I'm having this problem too, filling up every couple of days though, it is definitely hard on the wallet. Advice appreciated here also.
Old Apr 16, 2002 | 12:23 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
All I would have to say is make sure all sensors are working properly, and do a tuneup on the engine. New Plugs/Wires/Cap/Rotor etc..
Old Apr 16, 2002 | 01:47 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
or just dont drive it everyday
Old Apr 16, 2002 | 01:56 PM
MikeS's Avatar
I don't know what kind of engine the original poster has, but as for the 305 TPI.... how many miles do you get on a tank?
Old Apr 16, 2002 | 02:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
My setup from the signature with a non LU converter I get around 17-18mpg around town.
TPIs get a lot better, there's one person on these boards, I forget his name gets 30mpg.
It's all in how well tuned and efficient your motor can be.
Old Apr 16, 2002 | 03:31 PM
85transamtpi's Avatar
My 85 got around 18mpg around town. Do a regular tune up and make sure everything is running properly.
Old Apr 17, 2002 | 07:39 AM
FyreLance's Avatar
I just got the car so I haven't checked the mileage or anything yet.
Old Apr 17, 2002 | 09:32 AM
MikeS's Avatar
Ok, just checking. I can't remember exactly what my gas mileage works out to be, but know that I get 250+ miles from a tank on everyday driving. All hwy gets about 320 miles. Of course, neither one uses the whole volume of the tank. This is usually on about 13 gallons.
Ok, I got a calculator...
approx 20mpg city
approx 25mpg hwy
This is an 87 TPI 305 w/5 speed
Old Apr 17, 2002 | 11:12 AM
could my poor gas milage be because of the different weather conditions encountered each day sence im carb
Old Apr 17, 2002 | 11:15 AM
FyreLance's Avatar
I really should check. I'm kinda stuck at school right now though so I'll have to get back to it. It does seem to do a lot better once you drive it in overdrive more often and don't gun it constantly, lol
I am in the process of replacing my fuel filter though so I'm hoping that will help. It's being a pain though, couldn't get the #$%@! thing off last night, and I don't wanna break my fuel lines...
Old Apr 17, 2002 | 11:52 AM
MikeS's Avatar
Speedfreaker,
You might run a search to see what some of the carb guys are getting for mpg. I know on my 84 (non computer carb'd 350 w/5 speed) I used all kinds of gas. 12 mpg if I remember right.
FyreLance,
Yeah, taking it easy makes a huge difference. Hope the fuel filter replacement goes ok. I don't really have much that'll help you with it. Are the fittings corroded or just tight? Other than that, new plugs, wires, cap/rotor and things will help you too. Oh yeah, I got a big improvement by resetting my timing to spec and fixing a high idle condition that I had.
Old Apr 17, 2002 | 12:19 PM
FyreLance's Avatar
Yes. :-)
I was gonna play with the timing but it seems that the distro cap is very hard to get to.. right up at the rear of the compartment where the hood meets the compartment, where there isn't much clearance...
Old Apr 17, 2002 | 12:22 PM
MikeS's Avatar
To adjust the timing, you'll need a timing light and either a distributor wrench ($30 i think), a wrench bent at an angle, or a crow foot wrench set. I use the crow foot wrench on the end of a wobble extension on my ratchet. Figured I didn't have an extra wrench to bend to reach the hold down bolt so since I had to buy something I'd get a set of crows feet (correct terminology?) for thirty something bucks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
customblackbird
Oct 1, 2015 04:30 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
