Will a V6 electric fan cool a V8?
Old Jul 9, 2002 | 04:42 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I found quite a few V6 camaros/firebirds at the junk yard with electric fans, and I was wondering if a V6 electric fan would cool my V8? My buddy has an 89 RS V6 with an electric fan and that thing moves alot of air. If not, is there any car that I could pull 1 (or 2) fans from and use?
Old Jul 9, 2002 | 09:24 AM
ede's Avatar
ede
i'd guess the radiator is differant and not the fan, if either are differant. i think a duel fan set up off a k car will fit on a f body and work.
Old Jul 9, 2002 | 03:49 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yeah the radiator has the upper and lower hoses reversed on the v-6...the fans should work though.
Old Jul 9, 2002 | 07:54 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If they worked on a V8 they'ed be called V8 fans.
Old Jul 9, 2002 | 08:04 PM
Engine: 406
Huh? So are you saying they wont work? Why not?
Old Jul 9, 2002 | 08:08 PM
Engine: 406
Then they would be called k car fans....
Old Jul 11, 2002 | 03:34 AM
bhaas's Avatar
They work just fine. I'm using one in my V8. Keeps it nice and cool. No probs at all in 90 deg. heat.
Brad...
Old Jul 11, 2002 | 04:10 AM
Engine: 406
I thought they would work...the radiators are about the same...demensionally (sp)
Old Jul 11, 2002 | 08:20 AM
bhaas's Avatar
Yup. Just got the ports and cap on backwards. Or I would have used it.
Brad...
Old Jul 11, 2002 | 12:08 PM
Blackened's Avatar
Don't mind this clearly uneducated answer.
ANY fan that moves the required amount of air and can be mounted to your radiator will work.
gta892000
Aug 11, 2019 11:16 AM
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
64goatman
Sep 9, 2015 01:09 PM
