Cam Break IN Procedure??
Old 07-21-2002, 06:17 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I've been using Mobil 1 since there has been about 1k miles on the engine, now it has about 15k miles.
Now to break in the cam, I can use the existing oil in there, but after that I have to change it. Or do I have to put fresh oil in and then change it again.
If I have to put in fresh oil, can I use cheap Super Tech Dino oil?
Also, last time my brother swapped a cam for me, he didn't hold it at 2k rpms for that long. How long should it be, 30 mins?
Old 07-21-2002, 07:21 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
folllow the directions on the box.
Just don't let the motor idle for the first little bit.
You want maxium oil splash lube on initial engine running.
Use Lots of "Cam Break in LUBE" on the lobes and lifter bottoms.
Fire the motor quickly and bring to 2000+ rpm right away.
If you have any fluid leaks or other trouble, shut 'er down.
If there is valve train noise, or low oil pressure, shut ,er down, pull the covers off and readjust the valves. that are out of wack.
Old 07-21-2002, 07:49 PM
ede
ede's Avatar
i use moly lube on the lobes and distributor drive gear. i'd change oil to 30w dino juice. run it between 1000 and 2000 set timing and check for leaks, take it for easy drive ,let it heat and cool. after 30 to 60 minutes i'd change oil and add 30w again and drive it for at least 500 miles then change to whatever you like.
Old 07-21-2002, 07:55 PM
Car: 99 Formula
Axle/Gears: 342
Cool thanks.
Old 07-21-2002, 08:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Definitely dinosaur juice... NO SYNTHETIC during the first couple of k miles on a new flat tappet cam. The lifters won't be forces to rotate by the imperfect lube of the dino sludge, so they'll fail. try to keep the RPMs above 1800 for the first few minutes of engine operation for the same reason. At the 1st oil change after the cam swap (1 - 1.5k miles) you can go back to synth.
i prefer white lithium for beakin lube; works about as well as moly but doesn't plug up oil filters or leave a pile of schmutz laying in the bottom of the oil pan.
Old 07-21-2002, 08:40 PM
Car: 99 Formula
Axle/Gears: 342
So RB don't change the oil right after the initial break in, not till about 1k miles then?
Is there anything wrong wtih using the assembly lube Comp will send me.?
Old 07-21-2002, 10:43 PM
F-BIRD'88's Avatar
The tube of Red assembly lube that camp cams includes in their kits is good stuff. Muck up the cam and lifters real good with it.
Old 07-21-2002, 10:50 PM
evil t/a's Avatar
Use ALOT of moly lube on the cam lifters and distributor gear , prelube the engine with a drill and when it starts bring it up to 2000 and leave it there for 15 -20 minutes. After that change the oil and use whatever oil you like then you can drive it however you want , the first 15-20 minutes is all the breakin that a cam needs.
Old 07-21-2002, 11:10 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
well how do i break in my cam cause its gonna be a rebuilt engine and i can;t just start i t and bring tit to 2 grand for 20 mins
Old 07-22-2002, 12:10 AM
F-BIRD'88's Avatar
Why is that?
Old 07-22-2002, 01:03 AM
AdmiralNahohkta's Avatar
Car: GTO
Engine: GM 350HO, 4.6 Overhead cam, 413 Wed
It worked for me.
Old 07-22-2002, 03:19 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Is the break in procedure the same for a roller cam?
Old 07-22-2002, 08:20 AM
Car: 99 Formula
Axle/Gears: 342
If I remember correctly roller cams don't need to be broken in.
Old 07-22-2002, 09:28 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
yeah really whats wrong with running a fresh engine at 2000rpms?, its gonna see it eventually anyway, and the higher rpm gives better oiling, i did and so does everyone i know
Old 07-22-2002, 12:10 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Thanks Mark.
Old 07-24-2002, 11:48 AM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Hey Mark, have you got the cam in the car yet? How is it running if you do?
Mark
Old 07-24-2002, 06:41 PM
Car: 99 Formula
Axle/Gears: 342
Mark
We're having a 3rd Gen Meet on Sat. so I delayed it just in case.
I'm ordering the cam tonite, I just got the Stealth intake.
Old 07-24-2002, 08:37 PM
goneracin's Avatar
Rollers, either hydraulic or mechanical, need no breakin. Its just a wheel. Bolt er in and go :lala: A flat cam has to wear in and kinda work harden the surfaces, and has to establish lifter rotation.
Jorlain
10-08-2015 01:57 AM
IROCtometal
09-09-2015 10:01 AM
Strick1
09-04-2015 07:11 AM
z28guy134
09-01-2015 11:50 PM
masonta
09-01-2015 06:40 PM
Quick Reply: Cam Break IN Procedure??
