Ultradyne Cam Recommendations
Old Jan 29, 2003 | 12:39 AM
onebadwagon's Avatar
hey guys i need help finding a cam for my motor.
this is what i have:
355 with ross flat top pistons, 6 inch eagle hbeam rods.
studded bottom end with stock crank,
Edelbrock 23* victor jr heads, ported and polished flow approximately
315 @ .625 lift
220 @ .625 lift
victor jr intake
800 cfm carb
3500 ish stall
3.73 rear gear
3500 lb car.
i want this motor to pull hard to 7500 rpm, want a fair idle (lenient) ive been looking at cams ground on 109* lobe separation.
i will spray a 250 shot on this car. but the most important thing is how it runs on motor.
a buddy of mine recommended ultradyne, ive had good experience with comp, but he is REALLY fast.
adam
Ultradyne guys, tell me what you think.
Old Jan 29, 2003 | 05:59 AM
ede's Avatar
ede
they make good cams, but so does a lot of other grinders, like comp, lunati, crane, and reed. my personal favorate is lunati. there really isn't a "best" cam nor "best" cam grinder.
Old Jan 29, 2003 | 06:01 AM
that is why im looking for ultradyne recommendations,
the guy who recommended them, happens to run 8s on motor, thats fast enough to make me give it a little thought.
ive seen what comp and crane have and can do, along with some other manufacturers.
adam
Old Jan 29, 2003 | 06:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I know people who work there, I would trust them.
Like ede said, we all develop our "preferred" supplier for whatever reason; but alot of the top grinders have really competent people working for them, and can do a good job.
At least find out what they recommend. Given your combo, they probably won't spec something that will spin that high and still make meaningful power. I doubt you'll get to make more than a couple of 7500 RPM passes at least before that crank lets go though, I'd keep it below 6500 it I were you.
Old Jan 29, 2003 | 06:12 AM
a good forged crank is on the way. i want to see what a stock one will do.
i wont be spraying heavily until i get a good crank
adam
Old Jan 29, 2003 | 06:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not a real wise experiment.
I can tell you what it will do after a few 7500 RPM blasts.... it will break. Right in front of the #1 rod journal.
Just hope it doesn't take any of those expensive parts around it when it does, or you'll need a whole lot more than just a better crank.
Old Jan 30, 2003 | 08:24 PM
thanks for the info, but i didnt hear anything about a cam recommendation from ultradyne.
adam
Old Jan 30, 2003 | 09:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Have you called them? I think they're in either Horn Lake or Southaven MS, about 300 yards from Memphis, area code 662 IIRC. I haven't seen anybody from there on this BBS giving cam recommendations lately, so it could be a while before you get one this way.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
