under car by spark plugs looks like egr valve
Old May 12, 2003 | 08:47 PM
james03's Avatar
Damn this car been pain anywyas i was told looked like oil leak was coming from valve cover gasket so i replaced them then under car near spark plugs a round metal object with hole for hose in it kind looks like the egr vavale however on bottom part engine i looked through all the books i think from what i can see its oil pump however i dont see anything showing where hose from there supposed to go any ideas?
Old May 12, 2003 | 08:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like either fan switch or knock sensor.
What kind of motor and where exactly is it? Which side, front or rear, up high or down low, etc.
Old May 12, 2003 | 09:24 PM
james03's Avatar
its a v8 305 durabuilt engine they put in its on passenger side right near spark plugs towards middle
Old May 12, 2003 | 09:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Fan switch
It's an electrical connector, takes a single wire connector.
So what kind of car is it? Does it have an electric fan? If it does, and there's nothing hooked to that fan switch, then the fan isn't coming on when it's supposed to, and you need to find the wire and hook it up.
Old May 13, 2003 | 12:22 PM
Vader's Avatar
I'll take what's behind Door #2 - the detonation sensor. One of us is gonna win the big one! The older KS has that big, funky, cone-shaped connector.
To make sure, measure the diameter of the sensor. How big around is it? Does it mount in the head or down low in the block?
Old May 13, 2003 | 03:56 PM
james03's Avatar
ist 85 camaro berlinetta the fan works though always runs im going look at it measure it today i thought was maybe oil pump i hate these manuals tehy suck thanks for ur inputs though
Old May 14, 2003 | 02:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm guessing you have either a Haynes or Chilton... you need the "big guy", from http://www.helminc.com . You can find them sometimes on eBay... they're used, and some are beat up, but they're usually cheaper.
Old May 14, 2003 | 07:14 PM
james03's Avatar
i have haynes.chilton and huge gm service manual but nothing looks like what im seeing it not switch it has a metal slot stickimng out u can tell its a hose that needs to be connected ill just take it mechanic around here fri im finally off
Old May 14, 2003 | 08:54 PM
bill88stang's Avatar
id say it could be a heat riser valve or maybe its called something else, mne was flapping in the breeze on my 86 i just took it off im pretty certain it just helps the engie warm up faster by dirverting air up by the valves
Old May 15, 2003 | 08:41 PM
gtabadboy's Avatar
Passenger side near the plugs is a fan switch.
I believe that the temp switch is on the drivers side screwed into the block with a single green wire going to it.
The knock sensor should be located on the drivers side lower portion of the block near the oil filter. I had a couple 80s motors and this is where they are.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaroken83
Aug 10, 2015 11:35 AM
djmarch
Aug 9, 2015 05:27 PM
